Scgreen620 Posted October 1, 2016 Report Share Posted October 1, 2016 any one done wood on their panels ? Like trim or some kind of nice detail if you have anything like that post them please Quote Link to comment
Lockleaf Posted October 1, 2016 Report Share Posted October 1, 2016 See Datmo's "feels like autumn", Filthy's "drag wag", and Tendril's "69 510 goon build" 2 Quote Link to comment
Scgreen620 Posted October 1, 2016 Author Report Share Posted October 1, 2016 Just went thru ally the post and nothing just on the dash ... Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 You must mean a wood veneer or stick on accent in wood? Remove dash cluster and all the knobs, peel and stick, put knobs and dash panel back in. Quote Link to comment
thisismatt Posted October 2, 2016 Report Share Posted October 2, 2016 Probably, but never looks good, so wiped from memory. Quote Link to comment
DatMo Posted October 2, 2016 Report Share Posted October 2, 2016 I was never a fan of the wood doors but I've seen wooden headliner and wood dash seemed nice because it had been done in other American cars etc. I made a wooden dash but wooden door panels wouldn't be harder anyways. Home Depot could be your best friend. Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 He means door panels? Why not say so? They have traditionally been covered foam padding on press board backing, usually vinyl. Wood will visually look 'too hard' on an interior piece, foam sheeting and fabric would look better. I don't know of any vehicles that had solid wood door panels. You could mactack the upper inside metal above the door panels that holds the window felt in wood grain. I did this on my 510 back in the day, using scrap GM exterior wood grain vinyl for the '75 trucks. It was somewhat stretchy and would form around the curved surface. 1 Quote Link to comment
Lockleaf Posted October 2, 2016 Report Share Posted October 2, 2016 1948 Desoto suburban. 4 different types of wood to make each door panel. Incredibly gorgeous. Quote Link to comment
Scgreen620 Posted October 2, 2016 Author Report Share Posted October 2, 2016 No no no not the whole door panel just a small trim no more than 2 inches wide ... Kinda like the chrome accent I seen on doors on 510s something small detailed like that Quote Link to comment
Scgreen620 Posted October 2, 2016 Author Report Share Posted October 2, 2016 http://0.tqn.com/d/classiccars/1/0/o/9/-/-/damageddoorpanel.jpg 1 Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 You could mactack the upper inside metal above the door panels that holds the window felt in wood grain. I did this on my 510 back in the day, using scrap GM exterior wood grain vinyl for the '75 trucks. It was somewhat stretchy and would form around the curved surface. It looked like solid wood when done. Quote Link to comment
Lockleaf Posted October 2, 2016 Report Share Posted October 2, 2016 That's the first time you've actually explained what you want. All you've said is "wood trim" "Not dash" before now. Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 Probably best if you do the dash gauge panel as well to match the doors. A dark walnut for cool colors like green and blue maybe a yellowish teak for warmer yellow and above colors? Quote Link to comment
thisismatt Posted October 2, 2016 Report Share Posted October 2, 2016 Walnut lightens considerably with age, fyi Quote Link to comment
datzenmike Posted October 2, 2016 Report Share Posted October 2, 2016 lol yeah... real walnut maybe but not plastic veneer. I painted the '74 1/2 ton boxes at GM. There was a guy there who only installed the wood grain trim all day after the paint shop. It came in rolls of peel and stick and often was damaged installing, leading to many pieces being thrown away as garbage. I was told to 'help yourself' and took some home. I watched how it went on with a dip in a bathtub of water to wet it before applying and then squeegee out the air and water bubbles. Hair drier to warm and soften it so it would flow around corners. Worked pretty well on the 4 dr 510. Quote Link to comment
Scgreen620 Posted October 3, 2016 Author Report Share Posted October 3, 2016 Sorry I don't explain so well Ohhh I see what you mean mike! Walnut it my favorite wood Do you have pics? Quote Link to comment
datzenmike Posted October 3, 2016 Report Share Posted October 3, 2016 Fuck no this was the mid '70s. Hell they barely had electric lights. Quote Link to comment
Scgreen620 Posted October 3, 2016 Author Report Share Posted October 3, 2016 Lol I would of loved to see that .. Quote Link to comment
edekalil Posted October 16, 2016 Report Share Posted October 16, 2016 Fuck no this was the mid '70s. Hell they barely had electric lights. LOL Quote Link to comment
