rundwark Posted September 29, 2016 Author Report Share Posted September 29, 2016 Alright, all loaded up again. Upside, the second engine pull took me only 3 hours and change to do, instead of an eternity like the first time :) Quote Link to comment
rundwark Posted September 29, 2016 Author Report Share Posted September 29, 2016 Your lucky the seller will work something out with you. Totally agree. He's a stand-up guy. I'll keep you all posted on the progress, thanks for all the advice so far. I'll definitely ask him to take pictures of everything. Quote Link to comment
Draker Posted September 29, 2016 Report Share Posted September 29, 2016 The engine pulls only get faster. Last one I did I had it back on the stand and it was still hot from running at operating temp. 1 Quote Link to comment
banzai510(hainz) Posted September 30, 2016 Report Share Posted September 30, 2016 I wonder if the Spray bar is part of the issue. I always take the alternator and water pump off to get a better angle when putting motor out /in so I don't hit the core support. As that is really a nice car!!!!!!!!!! Quote Link to comment
Stoffregen Motorsports Posted September 30, 2016 Report Share Posted September 30, 2016 If the rod bearing was spun or beat up, the only right way to deal with it is a complete engine disassembly. If you find out that the repair was done by simply replacing the bearing, or any other means that did not involve having the crank out of the block, definitely be worried. Why should the crank come out? So the oil galleys in both the block and the crank can be cleaned. Bearing material breaks up into chunks and flakes and can find it's way into the small oil galleys, and if it's not cleaned out properly, it will happen again after the repair. And that's assuming the crank, rod and piston are even salvageable. 1 Quote Link to comment
rundwark Posted October 1, 2016 Author Report Share Posted October 1, 2016 I wonder if the Spray bar is part of the issue. I always take the alternator and water pump off to get a better angle when putting motor out /in so I don't hit the core support. As that is really a nice car!!!!!!!!!! Thanks Hainz! I left them both on but it sure is tight getting the engine out, or worse, back in. Especially the water pump. I don't think I could've pulled it off without the leveler on the hoist for the tiniest little adjustments to get those extra needed millimeters on each side. Quote Link to comment
datzenmike Posted October 1, 2016 Report Share Posted October 1, 2016 Spin the filter off and empty out, cut open if you want. It will be full of metal flakes and sandy chunks.The oil pump will be beyond toast by now also. 2 Quote Link to comment
rundwark Posted October 24, 2016 Author Report Share Posted October 24, 2016 Hey all, a quick update: I have the engine back. Like I wrote earlier, the seller offered me a full refund right away, but I asked him to check out the engine and see if it's worth fixing instead. If it is, he still has an engine he wants to sell and it's still an engine I want to buy. He tore the block down and it turned out to be a problem with the #3 rod bearing. The whole idea was: if we can rebuild it at a reasonable cost, we'd do it at his expense, and if not, he'd give me my money back. After getting quotes from the machine shop, we decided to move forward with the rebuild. He had the crank and that one rod reconditioned, honed the cylinders, and reassembled the engine with new pistons rings and new rod and main bearings. Along the way, we exchanged lots of pics and ideas over email, and learned that the crank's knife-edged and the Ross forged pistons have a bit of a dome to them, giving us more confidence the engine's worth saving. I installed it yesterday (with a fresh oil pump), put on all the ancillaries today, and fired it up tonight: 1 Quote Link to comment
DatMo Posted October 24, 2016 Report Share Posted October 24, 2016 Awesome man! 1 Quote Link to comment
KoHeartsGPA Posted October 24, 2016 Report Share Posted October 24, 2016 Sounds good! Quote Link to comment
Stoffregen Motorsports Posted October 24, 2016 Report Share Posted October 24, 2016 That's great that he helped you out instead of ducking for cover. Now if it doesn't blow up in the first 100 miles, it will probably be good for a long time. The bathtub curve. 2 Quote Link to comment
scooter Posted October 29, 2016 Report Share Posted October 29, 2016 Post tits or burnout Quote Link to comment
