Newbie could use some help on (sort of) an SD20 swap - removing AC and power steering
tdskip
OK, not really a Datsun, but I have 510 friends and after reading content on this site I am thinking I found the right group of inspired people to provide some coaching.
Basically I am putting a Silvia S14 SR20DE into this car (1967 Triumph TR4a) and will face a number of the same issue many of you have when doing a similar swap into a Roadster or 510. Quick back story;
C30C5583-A590-4A2A-B60E-AFDAA04204D3_zps
This is my 1967 Triumph TR4a  that sat unloved in Seal Beach in Orange County for 22 years before I pulled it out of a garage.. The darn thing just ate it's under 100 mile professionally rebuilt engine and I am more than slightly fed up with it. It is going to run me around $4,000 to get it rebuilt AGAIN and I realized that for not wildly different money I could install a SR20-family engine and have a better, more modern, better support engine attached to a proper 5 speed that would be both more powerful and lighter. As you can tell from the picture she is a driver, and my intention is to use her for long distance touring events in/around SoCal.
OK - so back to the question at hand. My SR20DE has A/C and power steering drives that I don't need and rather than inviting a solution to removing those I seems like people here will have solved that issue far better than I would. Is there a go-to solution on removing those bits and simplifying the belt set up for just the water pump and alternator?
Thanks in advance for the help!
  • Replies 3
First, thank you for the response. Very helpful and much appreciated.
So it looks like I can leave the water pump and alternator as connected and just remove the power steering and AC belt / ancillaries then. Other than appearance / being tidy is there any reason to swap out the pulley for a single row?
