datzenmike Posted October 4, 2016 Report Share Posted October 4, 2016 Same spline count. This is the important thing. 1 Quote Link to comment
nissan720 Posted October 4, 2016 Author Report Share Posted October 4, 2016 so the spilne count should be the same for the 82 and 84? 1 Quote Link to comment
wayno Posted October 4, 2016 Report Share Posted October 4, 2016 so the spilne count should be the same for the 82 and 84? All 720 trucks have the same spline count except for the later 4X4s with the C200 rearend, and the dually axles with the C200 rearend, fact is all trucks with H190 rearends have the same spline count from 1966 Datsun 520 thru the 1986 Nissan 720, they may not have the same length axles though, the track width has gotten wider over the years. 1 Quote Link to comment
datzenmike Posted October 4, 2016 Report Share Posted October 4, 2016 The '84 S12 does have 29 spline truck side gears in it, probably the only Nissan that does. All other car applications are 23 spline. 1 Quote Link to comment
G-Duax Posted October 4, 2016 Report Share Posted October 4, 2016 My list shows '82-'83 S110 200SX, the '84 S12 with a CA20 engine, and maybe the early '80s Maxima wagon. Oh, and the very early Japanese Cedric/Gloria 330/430 with an L20. In fact, I've thought about bringing in a set of 430 axles to see if they are the correct length, because they are 5-lug. It's just that they are hard to find, expensive, and heavy, so it's a lot of $$ to gamble with. 1 Quote Link to comment
datzenmike Posted October 5, 2016 Report Share Posted October 5, 2016 I never looked any farther, but yes the H-190 S110 were 29 spline truck side gears also. 810 and Maxina were 23 spline side gears.. 1 Quote Link to comment
nissan720 Posted October 16, 2016 Author Report Share Posted October 16, 2016 finally had a chance to pick up my rear end complete drum to drum they pulled it out 100.00 and yes it had a great set of drums on it.truck had just a little over 100,000 miles.also got the speedo gear .can u remove that speedo gear and place it on the speedo gear shaft thats presently in the truck.would have had the rearend before now,but hurricane Matthew got in the waywill my drive shaft bolt in without any modification?. 1 Quote Link to comment
nissan720 Posted October 22, 2016 Author Report Share Posted October 22, 2016 i have installed the rear pumpkin,now need to work on the speedo gear 1 Quote Link to comment
nissan720 Posted October 29, 2016 Author Report Share Posted October 29, 2016 got that pumpkin installed .what a difference!! lovin it. 1 Quote Link to comment
