Ignition coil issue. HELP!
BestyBlue77
  • Replies 3
Electricity will always look for the easiest path to ground. With a plug wire, or wires, off the easiest path used to be the spark plug but now it jumps to the coil negative terminal. As stated leave the ignition switch off and use a remote starter or pull the plug wire off the distributor cap and lay on a grounded surface where the spark will do no harm.
