StewyN Posted September 13, 2016 Report Share Posted September 13, 2016 Hey guys got a quick one here, Ive found multiple posts on bigger tires for 4x4s but none for 2wds. i got handed a set of 235/75/15 rims and tires, for free, and i was just wondering if id have issues putting these on my 2wd? if so is there a smaller size with 15 inch rims you'd recommend? i kinda wanna go as big as i can with the 15s. thanks for your input. 1 Quote Link to comment
bilzbobaggins Posted September 13, 2016 Report Share Posted September 13, 2016 um....put em on and see what happens? 1 Quote Link to comment
Lockleaf Posted September 13, 2016 Report Share Posted September 13, 2016 I would be surprised if anything over 28" in diameter would fit without rubbing 1 Quote Link to comment
flatcat19 Posted September 13, 2016 Report Share Posted September 13, 2016 Those are big tires for a stock height 2WD. Quote Link to comment
datsunaholic Posted September 13, 2016 Report Share Posted September 13, 2016 That's the size on my 620 4X4, which is 6" higher than stock, and the front fenders had to be clearanced even then. Quote Link to comment
Crytek89 Posted September 13, 2016 Report Share Posted September 13, 2016 I'm running 275/40ZR17 on my rears and 245/40ZR17 on the front - the front wheelwell had to be hammered in a bit, but they fit alright after. Quote Link to comment
Rjawm Posted September 13, 2016 Report Share Posted September 13, 2016 Just to try and help with samey samey measurements and some overall reference... 235/75-15 = 28.88" Overall Diameter (Most Import 4wd trucks of this era came with 225/75-15 as stock) 275/40-17 = 25.66" O.D. 245/40-17 = 24.72" O.D. 195/75-14 = 25.52" O.D. (Stock on most 720 2wd's) 205/75-14 = 26.11" O.D. (Optional on some 720 2wd's) 195/60-15 = 24.21" O.D. (What I have on a 720 2wd with 3" drop right now) Quote Link to comment
datzenmike Posted September 13, 2016 Report Share Posted September 13, 2016 Hey guys got a quick one here, Ive found multiple posts on bigger tires for 4x4s but none for 2wds. i got handed a set of 235/75/15 rims and tires, for free, and i was just wondering if id have issues putting these on my 2wd? if so is there a smaller size with 15 inch rims you'd recommend? i kinda wanna go as big as i can with the 15s. thanks for your input. 29" is what came on the 4x4 so I doubt 2wd will work well unless lifted. If your differential is 3.889 those tires will drop the overall ratio to 3.4. That's 12% out on speedometer... You think you're going 60 but really you are going 68. Yeah the cops will like that. This is terrible for performance and will make the truck very sluggish in town. Bigger? you mean wider with 15"??? Stock 14s are 7.6" wide and 25.5" tall 230/60R15 are 9" wide but same height as the stock 14" tires. No change but wider. 255/50R15 are 10 " wide same height. No change in performance and speedometer but wider Quote Link to comment
