Stoffregen Motorsports Posted September 10, 2016 Report Share Posted September 10, 2016 I've got a buddy up here with a Z24 equipped 720 4x4 and he just put on a DGV Weber. The kit he purchased included enough doo-dads to make the carb look like it belongs there. I don't know how, but his passed smog testing...! If it looks stock, uses the stock air cleaner, has enough tubes and wires coming out of it, maybe they won't notice. 1 Quote Link to comment
bilzbobaggins Posted September 10, 2016 Report Share Posted September 10, 2016 You can adapt the factory air cleaner with modification or buy an adapter for it. Hope this helps 1 Quote Link to comment
racerx Posted September 10, 2016 Report Share Posted September 10, 2016 I think this os in the " how to section" 1 Quote Link to comment
bushcat Posted September 12, 2016 Author Report Share Posted September 12, 2016 So, he's worked on the carb and the fuel lines. Begin to drive the truck and it would run fine for ten minutes then the engine would stop. He lowered the gas tank and discovered rust and particles on the tank. he believes that these particles may be breaking of and clogging the flow of fuel. He put some nuts in the tank with some clean gas and has shaken it around. He still doesn't want to send it home, he would rather have it taken to a shop that professionally cleans gas tanks to bring it back to new condition before sending it home with me so he can fully stand behind the work. the carb work plus what he's done to the gas tank is already 500. He said he would cut his labor charge for the fuel tank if I paid to have it professionally cleaned so he can be comfortable sending the truck home. So I'd be looking at something like 600 for carb work, fuel line replacement, fuel filter replacement, and the gas tank removed, professionally cleaned, and reassembled. My choices: 1. Have him put the gas tank back on and pay 500 and hope that the particles that come off aren't enough to plug the bottom drain hole of the fuel tank. Then just clean the fuel filter as residue comes out. 2. Have the gas tank it professionally cleaned and reassembled for a total of 600 for the entire job. Pay the man, and drink a large beer. 1 Quote Link to comment
racerx Posted September 12, 2016 Report Share Posted September 12, 2016 Good to install a plastic see through gas filter. 1 Quote Link to comment
bushcat Posted September 12, 2016 Author Report Share Posted September 12, 2016 1 Quote Link to comment
bushcat Posted September 12, 2016 Author Report Share Posted September 12, 2016 Yeah, I will make sure to do that. Thanks racerx. 1 Quote Link to comment
mhub91 Posted September 12, 2016 Report Share Posted September 12, 2016 Datzenmike nailed it on the head with fuel issue... 1 Quote Link to comment
datzenmike Posted September 12, 2016 Report Share Posted September 12, 2016 Have it towed home he's milking this for $500 you could have had a new carb. Pay him off and get away from him... he smells your money. Anything in the tank will be caught by the fuel filter. Put a new one on and try driving it home or tow it. 2 Quote Link to comment
Charlie69 Posted September 13, 2016 Report Share Posted September 13, 2016 I am curious about the 9/10s functionality! What tenth is not going to function? Will it pass smog and be reliable? 1 Quote Link to comment
mhub91 Posted September 13, 2016 Report Share Posted September 13, 2016 Have it towed home he's milking this for $500 you could have had a new carb. Pay him off and get away from him... he smells your money. Anything in the tank will be caught by the fuel filter. Put a new one on and try driving it home or tow it. Exactly my thoughts..... 1 Quote Link to comment
Stoffregen Motorsports Posted September 13, 2016 Report Share Posted September 13, 2016 I would be concerned about the flakes in the tank coming off and exposing a pinhole. Take the tank out and have it professionally cleaned and sealed. I know there are a lot of shady mechanics out there, but why would you expect anyone to cut their labor for work that they have done. If you trust the guy, pay him. He's probably got a family to feed. 1 Quote Link to comment
bushcat Posted September 13, 2016 Author Report Share Posted September 13, 2016 Point taken... I think I was more upset about not being notified when work was about to go over the estimated amount. It put me in a tight spot when the tank was already off the truck. I didn't have much of a choice. I was also concerned that we went to the most expensive fix before maybe addressing the cheaper alternatives. I know diagnosing is not black and white. I think he means well and he wants to stand by his work and that's why he doesn't want to send it home without taking care of this rusted tank that may give problems down the road. I would be concerned about the flakes in the tank coming off and exposing a pinhole. Take the tank out and have it professionally cleaned and sealed. I know there are a lot of shady mechanics out there, but why would you expect anyone to cut their labor for work that they have done. If you trust the guy, pay him. He's probably got a family to feed. 1 Quote Link to comment
racerx Posted September 13, 2016 Report Share Posted September 13, 2016 Lesson learned, that is all, dont be too hard on yourself. We all did something like that. 1 Quote Link to comment
bushcat Posted September 13, 2016 Author Report Share Posted September 13, 2016 :) Lesson learned, that is all, dont be too hard on yourself. We all did something like that. Quote Link to comment
Cheetahking Posted September 14, 2016 Report Share Posted September 14, 2016 I had an issue with a 510 tank - that many filters could not fix. It was exactly like your tank. the problem only went away when I got the tank dipped. Solved everything. I think your mechanic is probably a good guy. While removing the tank is not a hard job - it is work. And figuring the time he spent diagnosing, carb work and tank RR it seems fair. Should he have contacted you regarding tank issue? yes. But until he took it out, he couldn't tell what the issue was. Having that work done in so cal would be more $ than he is quoting I'm sure. If you don't clean the tank, you could constantly be chasing this issue. Quote Link to comment
bushcat Posted September 14, 2016 Author Report Share Posted September 14, 2016 @cheetahking thanks for sharing your experience. like I said, I think he means well. the communication was rough to start but it's steadily improved. I didn't want to take the truck home without his word that he thinks he covered all the problems that were causing it to not run a 100%. At least I know this won't be an issue down the road, the truck did sit for a year and a half after this lady's husband died which probably contributed to the rust flakes and build up. I was partly sticker shocked that I would be paying that much after just buying it, hoping it was only needing some carb work. I wouldn't feel comfortable letting something go in my business that had the potential for error. Most of it comes back on me for not being prepared for these potential problems and not being more educated about the purchase. It definitely would have affected my offer price. Quote Link to comment
datzenmike Posted September 14, 2016 Report Share Posted September 14, 2016 This tank is CLEAN. You should see a dirty one. Point taken... I think I was more upset about not being notified when work was about to go over the estimated amount. It put me in a tight spot when the tank was already off the truck. I didn't have much of a choice. I was also concerned that we went to the most expensive fix before maybe addressing the cheaper alternatives. I know diagnosing is not black and white. I think he means well and he wants to stand by his work and that's why he doesn't want to send it home without taking care of this rusted tank that may give problems down the road. Bless you for being so trusting and naive. Unfortunately it will cost you in this world. The longer your car stays there the more he will find wrong and charge for. Quote Link to comment
bushcat Posted September 14, 2016 Author Report Share Posted September 14, 2016 Looked kind of clean to me to be honest but this was after he shook around clean gas with bolts and nuts. I was paying 120 to have him just put it back on so the extra $80-100 to have it professionally cleaned and sealed made sense. Quote Link to comment
bushcat Posted September 30, 2016 Author Report Share Posted September 30, 2016 Finally got her back. New fuel tank, fuel filter (they went through 3), new fuel lines, carb rehaul and a bulb replacement. I think I owe you guys a picture. Here she is... Quote Link to comment
racerx Posted September 30, 2016 Report Share Posted September 30, 2016 Nice..feels good it got fixed, doesn't it? What part of Bay Area? Quote Link to comment
bushcat Posted September 30, 2016 Author Report Share Posted September 30, 2016 Yes, feels good not breaking down! I live in Oakland, now starts the other projects. Quote Link to comment
bushcat Posted September 30, 2016 Author Report Share Posted September 30, 2016 You can see my other project in the picture. My blue geo metro! Quote Link to comment
