Youngblood29 Posted August 31, 2016 Report Share Posted August 31, 2016 How can i raise my datsun 620 1974 1 Quote Link to comment
flatcat19 Posted August 31, 2016 Report Share Posted August 31, 2016 Front or back. Reverse of lowering. Reindex torsion bars opposite way of lowering. Put axle on other side of springs. 1 Quote Link to comment
mcordero8 Posted August 31, 2016 Report Share Posted August 31, 2016 Now why the hell would you want to do that? 1 Quote Link to comment
Youngblood29 Posted August 31, 2016 Author Report Share Posted August 31, 2016 both ends 1 Quote Link to comment
hobospyder Posted August 31, 2016 Report Share Posted August 31, 2016 how high are we talking? 1 Quote Link to comment
flatcat19 Posted August 31, 2016 Report Share Posted August 31, 2016 Are you trying to lift the thing or un-lower it? We ain't mind readers. Speak up. More words. Way more pics. 1 Quote Link to comment
Youngblood29 Posted August 31, 2016 Author Report Share Posted August 31, 2016 i would like to raise it as much as i can using the torsion bars. Its at stock height right now. 1 Quote Link to comment
Youngblood29 Posted August 31, 2016 Author Report Share Posted August 31, 2016 Would like to raise like this 2 Quote Link to comment
bilzbobaggins Posted August 31, 2016 Report Share Posted August 31, 2016 That's got a solid front axle 1 Quote Link to comment
Lockleaf Posted August 31, 2016 Report Share Posted August 31, 2016 That one is 4x4 with big leaf springs under front and rear both. To get yours that high will require significant modification of both suspension and steering. If you are not capable of major modification, you might be better off dropping your 620 on a 720 4x4 frame. Still hard, but much easier. 1 Quote Link to comment
Lockleaf Posted August 31, 2016 Report Share Posted August 31, 2016 i would like to raise it as much as i can using the torsion bars. Its at stock height right now. Maybe 2 inches before you start running into major positive camber issues. 1 Quote Link to comment
Youngblood29 Posted August 31, 2016 Author Report Share Posted August 31, 2016 So how high can i raise it using the torsion bars 1 Quote Link to comment
flatcat19 Posted August 31, 2016 Report Share Posted August 31, 2016 So how high can i raise it using the torsion bars Maybe 2 inches before you start running into major positive camber issues. 1 Quote Link to comment
flatcat19 Posted August 31, 2016 Report Share Posted August 31, 2016 If your truck is not a 4x4 leave it alone. 2 Quote Link to comment
Lockleaf Posted August 31, 2016 Report Share Posted August 31, 2016 You could PM kneesamo And ask what is done on his truck. This is his. I believe it's 2wd. 1 Quote Link to comment
wayno Posted August 31, 2016 Report Share Posted August 31, 2016 You can get a few inches in the front re-indexing the torsion bars, but nothing close to the photo you posted. The rear can be done fairly easy, just weld new perches on the axle an put it under the leafs, the issue with this is that the front cannot keep up with the back, perhaps a spacer will help between the upper control arm and the ball joint. You can likely appear to be higher doing a body lift, 2 or 3 inches is about it for that without running into issues, and bigger tires will help also. 1 Quote Link to comment
datzenmike Posted August 31, 2016 Report Share Posted August 31, 2016 The suspension and steering is designed to work through a small range at or near stock height. Going up or down will throw the camber and toe way off. The toe can be adjusted. Camber can only be adjusted so far until all the factory shims are removed and then that's about it. I managed a 4" body lift but do not recommend this. 2" would be optimal. Even then 10.5 x 31 tires did not clear the floor pan under the pedals. (and they rubbed the frame on turns) In addition steering is almost impossible with tires that big. I made up a power steering system for it. Now the gearing was wrong for the tire size and performance and crawl speeds were no good for off road. I did get another 12" clearance by swapping a Toyota 4x4 front axle in and using very arched F-150 leaf springs on all four corners. Would I do it again... never. 2 Quote Link to comment
