Kadaj Posted August 26, 2016 Report Share Posted August 26, 2016 What's up guys got another problem here with my 620, I have an L20B motor with a webber carb in my 73 that's how I purchased the truck. Truck has been fine minor problems I could take care of myself but being new to carburetors I think I'm experiencing a problem out of my league.so yesterday I drove to work which is a mile and a half away from my house,truck was great ran like any other day, as I went to drive home I got down the road to my first stop and the car just shut down,didn't stall just shut down oil light came on. So I immediately restarted the truck and drove to the side of the road, I went to start it up again and I had to give it a few pumps on the pedal for gas. Then as it started I took my foot off the gas and instantly shut down again. So I drove it home keeping the gas pressed as I came to a stop. I thought it was something minor such as the fuel filter and pump so I replaced the fuel filter and the pump, but that fixed nothing so I checked a leak somewhere nothing. When I got the truck the previous owner rebuilt the carb new distributor, coil, and wires. So I'm in need of some help if you guys could thanks in advance! Oh and another thing driving down the road while pressing the gas if I eased on the pedal I had no power therefor I had to floor the pedal to get speed maybe this is a symptom of what's going on. Again thanks guys! Quote Link to comment
flatcat19 Posted August 26, 2016 Report Share Posted August 26, 2016 Will it run of you spray starting fluid down the carb? Quote Link to comment
G-Duax Posted August 26, 2016 Report Share Posted August 26, 2016 Sounds like you have a bunch of crap in the carb, plugging up all except the main jets. But it could also be a stuck float, and you are getting way too much gas, except if you have the throttle wide open. When it is running, is it blowing soot out the tail pipe ? If it is, it's too rich. Pull the spark plugs, to see if they are black with soot (too rich), or bone white (too lean). 2 Quote Link to comment
racerx Posted August 26, 2016 Report Share Posted August 26, 2016 If u have a plastic gas filter, see if its dirty. 1 Quote Link to comment
banzai510(hainz) Posted August 26, 2016 Report Share Posted August 26, 2016 cycle the gas linkage , You see gas squirting in the carb? this is the accel pump.meas you have has and pump is working. also if stock carb I think the later datsuns have a idle cutoff selioniod. see if the wire fell off. or maybe maybe its plugged. this is a simple fix Quote Link to comment
datzenmike Posted August 26, 2016 Report Share Posted August 26, 2016 What's up guys got another problem here with my 620, I have an L20B motor with a webber carb in my 73 that's how I purchased the truck. Truck has been fine minor problems I could take care of myself but being new to carburetors I think I'm experiencing a problem out of my league.so yesterday I drove to work which is a mile and a half away from my house,truck was great ran like any other day, as I went to drive home I got down the road to my first stop and the car just shut down,didn't stall just shut down oil light came on. So I immediately restarted the truck and drove to the side of the road, I went to start it up again and I had to give it a few pumps on the pedal for gas. Then as it started I took my foot off the gas and instantly shut down again. So I drove it home keeping the gas pressed as I came to a stop. I thought it was something minor such as the fuel filter and pump so I replaced the fuel filter and the pump, but that fixed nothing so I checked a leak somewhere nothing. When I got the truck the previous owner rebuilt the carb new distributor, coil, and wires. So I'm in need of some help if you guys could thanks in advance! Oh and another thing driving down the road while pressing the gas if I eased on the pedal I had no power therefor I had to floor the pedal to get speed maybe this is a symptom of what's going on. Again thanks guys! Sounds like the carb. Partly plugged jet, bit of dirt maybe. Pull a plug and look. If white and very clean it's a part blocked jet and the engine is running lean. Lean running always over heats the plugs and the porcelain tip of the electrode become shiny white. Normally they would be tan or light brown. It may be flooding or running too rich. This also would require flooring the gas pedal to keep running. Choke may be on or stuck on or the float needle dirty and not closing and the fuel level in the carb over flowing. Pull a plug and look at the end. Of black with soot it's running way too rich. If you are only 1 1/2 miles from home the choke would never have a chance to shut off. The engine would never get warmed up either. Quote Link to comment
Kadaj Posted August 26, 2016 Author Report Share Posted August 26, 2016 Ok thanks guys gonna check all this out once I get home from work today I'll keep you guys posted Quote Link to comment
banzai510(hainz) Posted August 26, 2016 Report Share Posted August 26, 2016 the idle mixture could just of out also. accell pump bad if you pump the gas and no squirting(look in side the carb) disconnect the choke wire and let the choke close off the carb and see if runs better. this is a sign of a block main jet as it run more on the 2nd barrel. 1 Quote Link to comment
racerx Posted August 26, 2016 Report Share Posted August 26, 2016 Check for vacuum leaks. 1 Quote Link to comment
Kadaj Posted August 28, 2016 Author Report Share Posted August 28, 2016 Ok guys so update checked the plugs they were a little darker than normal the porcelain was white, I check the cut off solenoid it didn't make a difference so I popped the filter off from carb and the left circle I assume a jet is wet and I can't couldn't get help so I didn't see if it was squirting but the right circle or jet is dry no gas at all so I took my truck to friend and he said the carb could be clogged which you guys had mentioned so he suggested I have it rebuilt so I will be taking it off to have it rebuilt. Thanks alot for the help guys! Quote Link to comment
datzenmike Posted August 28, 2016 Report Share Posted August 28, 2016 You can rebuild this yourself you know. It ain't rocket science. Why work 5 hours to pay some dick mechanic for each hour he needs to do the same job????/ He knows as much about a Weber as you do. Why pay him to learn how to rebuild it??????? Here's all you need. Rebuild Kit.... not really needed as you are only cleaning it. Large table with newspaper covering Philips screwdriver 12mm wrench Carb spray with plastic straw. Old toothbrush Needle nose pliers Roll of paper towels 2 Hours of your time You know now how to do this and you get to keep your money and this knowledge. Quote Link to comment
G-Duax Posted August 28, 2016 Report Share Posted August 28, 2016 Just be careful when you pull the top off, so you don't rip the gasket. Most likely you can find an exploded view on-line. Quote Link to comment
