Lost_Player Posted August 19, 2016 Report Share Posted August 19, 2016 So I'm changing my clutch hydraulic system, new clutch master and slave cylinders since my old clutch cylinder was leaking pretty bad and by the looks of it the last owner did not maintain it properly. I went and bought the new cylinders and when I was placing the new slave cylinder i noticed the there was no place to attach the spring that connect from the slave cylinder and the clutch fork. I'm wondering if I can run the setup without the spring or it's better find some way to place it. Quote Link to comment
]2eDeYe Posted August 19, 2016 Report Share Posted August 19, 2016 Welcome aboard. :) Someone added a spring due to a faulty pressure plate, slave or master. There is no spring there from the factory. Quote Link to comment
datzenmike Posted August 19, 2016 Report Share Posted August 19, 2016 I think the 521 and the 510 had the adjustable push rod between the slave and the clutch arm... maybe the '73 620 too. The clutch arm had a hole through it for the push rod and the push rod had an adjustment nut. All had a return spring and a small hole on the clutch arm and the slave for it. I think someone had the same problem and they just bought a generic spring and tied it to the slave somehow. The reason the newer slaves didn't have the spring is that they didn't need them as they adjusted automatically. If you have the newer one you may not need it also. 1 Quote Link to comment
Lost_Player Posted August 19, 2016 Author Report Share Posted August 19, 2016 Thanks. :) Hmmm that would make sense.. I tried to find slaves with the spring hole in them but they are really hard to find. And yeah the 510 has a adjustable pushrod between the slave and clutch arm.. And I'm 99% sure that the cylinders that where on the car came from the factory like that.. not sure about the spring. I just went through the service manual and saw no spring. I'll probably run it like this and see what happens. Quote Link to comment
]2eDeYe Posted August 19, 2016 Report Share Posted August 19, 2016 Shows what I know about the earlier stuff :lol: Quote Link to comment
flatcat19 Posted August 19, 2016 Report Share Posted August 19, 2016 521 slaves have the hole for return spring. Quote Link to comment
banzai510(hainz) Posted August 19, 2016 Report Share Posted August 19, 2016 nice to have the spring but is not needed if adjusted right Quote Link to comment
kelowg Posted August 20, 2016 Report Share Posted August 20, 2016 A slave with bleeder screw on back end, hook spring into hole in bleeder. Prefer a return spring,to make sure t/o bearing doesnt always riding on pp fingers. Quote Link to comment
datzenmike Posted August 20, 2016 Report Share Posted August 20, 2016 Just checked and the early 620 does NOT have the adjustable clutch arm. The clutch adjustment is only to compensate for clutch wear as the disc gets thinner. No mention is made about the release bearing rubbing the diaphragm fingers. If you think about it as long as the clutch arm is properly adjusted there may be some rubbing but definitely no load on the bearing. That's a hefty size bearing and certainly it could spin if in contact with the clutch fingers and no damage done. The later non adjustable slave has an internal feature that compensates for clutch wear. Indeed when the pedal is released the diaphragm spring pushes everything back to wait for the next clutch operation. As the disc wears down the slave piston is pushed back but not as far. This would indicate that the release bearing is in constant contact with the diaphragm fingers. There is no clutch arm clearance. If you install a spring you will force the slave piston all the way back to it's starting position. From then on you will have to continue checking and tightening the adjustment as the clutch wears and the clearance increases. Without the spring, the slave self adjusts. Just leave the adjustable rod where it is. Many people have swapped zx 5 speeds with their own non adjustable clutch arm and non adjustable slave into their 510s with stock clutches with no ill effects to the release bearings.. Quote Link to comment
edekalil Posted August 21, 2016 Report Share Posted August 21, 2016 Haven't had time to look at mine, I have some new springs just got to get the time to put them on. So far the car has been fine with out it. But I do plan to put it on. Quote Link to comment
datzenmike Posted August 21, 2016 Report Share Posted August 21, 2016 If you have the newer style slave you don't need it. If you put it an you will need to adjust it and keep adjusting it as needed. Quote Link to comment
