zeke5551 Posted August 18, 2016 Report Share Posted August 18, 2016 Has anyone used a H20 or H20-2 forklift motor in a B210 or 310? I'm looking for one to see, measure,,.think about. I've heard it is based on an A15 and is the same size, Any clues or does anyone have a source? thanks, zeke Quote Link to comment
datzenmike Posted August 18, 2016 Report Share Posted August 18, 2016 What will you do for a transmission? Or does it mate to the A series transmissions? Fork lift engines don't sound that fast to me. Quote Link to comment
wayno Posted August 18, 2016 Report Share Posted August 18, 2016 OK, as far as I know, the Roadster guys with R16 engines want the H20 engine as it is a stroked R16. Personally I would stick with the A series engine, as everything having to do with the Datsun Roadster is expensive, you will have to find a Roadster 4 speed(fairly easy but a 4 speed), or source a Roadster 5 speed(expensive), or source a SD series diesel case and use a 71B transmission of some sort, all these are either hard to find or expensive or not what you wanted to start with. Just bore out your A series engine. 1 Quote Link to comment
Doctor510 Posted August 19, 2016 Report Share Posted August 19, 2016 Has anyone used a H20 or H20-2 forklift motor in a B210 or 310? I'm looking for one to see, measure,,.think about. I've heard it is based on an A15 and is the same size, Any clues or does anyone have a source? thanks, zeke The H2O is based on the 5 Main bearing R16 roadster motor, very different animal from the A15 Quote Link to comment
zeke5551 Posted August 19, 2016 Author Report Share Posted August 19, 2016 This is why I love these forums. My research (google) lead me to believe the H20 was a derivative of the A series motor and the transmission bolt pattern would be the same. I need a very short engine for a conversion I'm working on. My goal is to put a full drive train and brakes from a Datsun in my 59 Morris Minor Traveler. The A series motors fit and hundreds of them have been put in MMs. I just wanted a little more than 1.4 or 1.5 liters. Also, I'm having a horrible time finding a rebuildible A14 or 15 in central California. Any help will be appreciated. I'll drive within a couple hundred miles of Fresno, Ca (horrible place if you're curious). I'm slowly backing out of the muscle car thing and going smaller. I have a stock 260Z and know how good a Datsun is...makes sense to through out the British junk from my MM and make a drivable car out of it. The forum won't let me post a WTB add yet, so if anyone can help me with an engine core, email me at zeke5551@comcast.net thanks, Zeke 1 Quote Link to comment
datzenmike Posted August 19, 2016 Report Share Posted August 19, 2016 Can't see putting an H20 in a fork lift. Is there another engine called an H20? Saw a Datsun fork lift once that had an A series in it. Quote Link to comment
wayno Posted August 19, 2016 Report Share Posted August 19, 2016 It's actually a very common conversion(just not talked about a lot), I believe there was one at Canby, and no one can tell unless they look at the block numbers. You just bolt all the "R" shit on it and you have a stroker, I don't recall if the head is different as once I converted over to a U20/5spd I didn't care anymore. Quote Link to comment
Lockleaf Posted August 19, 2016 Report Share Posted August 19, 2016 The h20 is usually setup with propane injection in the fork lift. I've actually talked to a couple of fork lift repair shops around here about buying a core from them. I almost bought a roadster 1600 a while back and was doing a bunch of research on the h20 block with the r16 head. Quote Link to comment
Tom1200 Posted August 22, 2016 Report Share Posted August 22, 2016 Zeke, I have a spare A15 that came out of a 210, it was running when it came out of the car. I'm in Las Vegas The A15 is intended as a backup motor for the 1200 coupe I race but I also have a prepped A12 so I would be willing to let go of the A15. I have the 5 speed overdrive tranny, I was hanging on to that as a back up as well but have since been able to get the mid close gear set repaired for my other tranny so I'd likely let it goes as well.I'm in a garage clearing mood so I could probably put together a complete package of stuff; motor, tranny, radiator drive shaft etc. I also have some dual valve springs and a lighter flywheel (14lb vs 22lb). As for performance the stock A15 is 80bhp; a mild cam (regrinds from Delta Cams are $75) a weber DGV carb ($50 used) and cleaning up the cylinder head will easily net another 10hp. If you go with an oval port cylinder head 100bhp is easy to attain for not a lot of bucks. That should make your Traveller scoot along nicely. If you ditch the cast iron exhaust manifold in favor of a header and go with the lighter flywheel the A15 will be down to 185lbs & the 60 series gearbox is only 54lbs. So that's just on 240lbs for both, quite a weight reduction over the standard Morris stuff. Quote Link to comment
