jeph Posted August 18, 2016 Report Share Posted August 18, 2016 So i took my transmission apart tonight and took a video of what i found out is the problem but i have no clue what im looking at. it seems like the lower gear behind the smaller front bearing is spinning on the shaft a little before catching, my question is, is it splined on the inside and mabey stripped? woodruf key? this video is taken with the transmission in 5th gear notice how much i can spin the input shaft before the output shaft starts to spin https://youtu.be/DxkmNePxMcI Quote Link to comment
datzenmike Posted August 18, 2016 Report Share Posted August 18, 2016 Two woodruff keys. 32214-58S61 couple a bux each. 1 Quote Link to comment
Draker Posted August 18, 2016 Report Share Posted August 18, 2016 Whats the history on this tranny? Quote Link to comment
jeph Posted August 18, 2016 Author Report Share Posted August 18, 2016 Whats the history on this tranny? it came out of a stock s14 240sx with 140k miles from a old lady and it had a rod knock. Two woodruff keys. 32214-58S61 couple a bux each. Nice! is it possible to press the end bearing off and pull that gear off or do i have to find a way to pull that whole stack out? i literally know nothing about transmissions but im good at everything else lol, this is my 4th transmission and tired of buying them so trying to fix it myself this time. Quote Link to comment
datzenmike Posted August 18, 2016 Report Share Posted August 18, 2016 Draw off the counter bearing (bottom) You may have to draw the top input shaft off with top and bottom gears together. 1 Quote Link to comment
thisismatt Posted August 18, 2016 Report Share Posted August 18, 2016 Here's the FSM section on the S14 manual trans for your disassembly pleasure: http://www.objext.com/mt.pdf 2 Quote Link to comment
jeph Posted August 18, 2016 Author Report Share Posted August 18, 2016 Here's the FSM section on the S14 manual trans for your disassembly pleasure: http://www.objext.com/mt.pdf Draw off the counter bearing (bottom) You may have to draw the top input shaft off with top and bottom gears together. Thanks a ton for the help!!! Quote Link to comment
datzenmike Posted August 18, 2016 Report Share Posted August 18, 2016 Here's the FSM section on the S14 manual trans for your disassembly pleasure: http://www.objext.com/mt.pdf MT 15 4/ Quote Link to comment
jeph Posted August 19, 2016 Author Report Share Posted August 19, 2016 got the gear off and its ruined lol What was left of the two woodruf keys. Quote Link to comment
jeph Posted August 19, 2016 Author Report Share Posted August 19, 2016 i cant believe that was holding 270ft lb torque and i even clutch dropped it a few times. Quote Link to comment
thisismatt Posted August 19, 2016 Report Share Posted August 19, 2016 Granny shifting, not double clutching like you should... :lol: 1 Quote Link to comment
datzenmike Posted August 19, 2016 Report Share Posted August 19, 2016 Yeah that's fuckt. New key ways could be cut but the cost... Unlikely you would ever have to take it apart ever again. Nothing to loose if you were to weld it on solidly in place. It's already out and apart. Quote Link to comment
jeph Posted August 19, 2016 Author Report Share Posted August 19, 2016 Granny shifting, not double clutching like you should... :lol: lucky the 10 pounds of boost diddnt blow the welds on the intake Quote Link to comment
jeph Posted August 19, 2016 Author Report Share Posted August 19, 2016 Yeah that's fuckt. New key ways could be cut but the cost... Unlikely you would ever have to take it apart ever again. Nothing to loose if you were to weld it on solidly in place. It's already out and apart. i was thinking that, i can get a new gear and keys easily but not the shaft, was thinking of throwing new keys and gear then welding her on top of that. Quote Link to comment
thisismatt Posted August 19, 2016 Report Share Posted August 19, 2016 lucky the 10 pounds of boost diddnt blow the welds on the intake Now me and the mad scientist got to rip apart the block and replace the piston rings you fried. Quote Link to comment
datzenmike Posted August 19, 2016 Report Share Posted August 19, 2016 FF... and I mean... for fuck sake, no more. 1 Quote Link to comment
jeph Posted August 19, 2016 Author Report Share Posted August 19, 2016 Now me and the mad scientist got to rip apart the transmission and replace the Counter gear you fried. fixed lol Quote Link to comment
