510 door handles, are front and rears different?
so, my 71 was already shaved when i bought it, while it looks fine I feel it looks much better with door handles. my question is, are the front and rear door handles different? found a guy selling two sets in pretty good condition but i don't want to buy both if i'll only be able to use one set. Was thinking about just buying them and selling them later if i can't use them but I'd like to know ahead of time.
Also: i have door poppers on it now, would i have to remove the cylinders for the handles to work again properly?
Thank in advance!
-Rob
  • Replies 6
Well different part numbers... for example....
Front Right 80605-23100 2 and 4 door
Rear Right 82605-23100 4 door and goon.
The front handle connects to a push rod the extends downward into the door lock mechanism.
The rear handle appears to connect directly to the door latch mechanism.
Are they the same... I don't think so. Will they work or interchange... possibly. Some parts are this way as in a 15" zx rim fitting a 510 hub.
Damn, thanks fellows. I will ask the seller if he knows if they are different.
I am not sure what this statement means
the front and rear are different for sure without a doubt
  • 1 month later...
