Max's 1986 Nissan 720 King Cab 4x4
  • Please log in to reply
167 replies to this topic
#161 captain720
captain720
  • Senior Member
  • PipPipPipPip
  • 607 posts
  • Cars:1986 and 0 Nissan 720 King Cab 4wd and 2wd, 1991 Chevy S10 2wd
Posted 21 May 2018 - 01:15 PM
Also if you put your socket driver on a 27 mil and then put that on the front lower pully and turn the starter it comes off because the socket driver braces against the framerail and it breaks it loose. Also if, when assembling or disassembling, you need to remove the cam sprocket then place a long socket extension in the cam sprocket hole and use your breaker bar to loosen bolt that holds cam sprocket on, remove this AFTER Timing chain tensioner is removed. If using the socket extension method to remove cam sprocket ensure that you place a rag between extension and head or you will scuff it.
1986 and 0 Nissan 720 kc with a 1984 Z24 (third engines the charm?) http://community.rat...y-first-pickup/
1986 and 0 Nissan 720 kc 2wd http://community.ratsun.net/topic/71766-one-wasnt-enough/
My channel https://www.youtube....KfpiwEzpECyevzw
Datsun=Project
#162 MaxChlan
MaxChlan
    Advanced Member
  • Members
  • PipPipPip
  • 175 posts
  • Cars:1986 Nissan 720 Deluxe King Cab 4x4
Posted Yesterday, 05:47 AM
Thank you! Removing the timing chain when you have the water pump off seems fairly straight forward; I just need to make sure that the engine is TDC Cyl. #1, pull the timing cover, mark the chain and sprocket, and release the tensioner, correct? Also, this is a non-interference motor, correct?
#163 captain720
captain720
  • Senior Member
  • PipPipPipPip
  • 607 posts
Posted Yesterday, 06:25 AM
If the chain falls off the pistons and valves hit each other.
Only turn it a little bit with chain off, but you will put it at TDC for head gasket anyways. Make sure that you replace chain and sprockets too, because the chains stretch.
Datsun=Project
#164 MaxChlan
MaxChlan
    Advanced Member
  • Members
  • PipPipPip
  • 175 posts
Posted Yesterday, 06:43 AM
Yeah, I have a timing kit on it's way; I am taking the head off today so that I can take it to my guy to make sure it's leveled and to replace the valve seals
#165 captain720
captain720
  • Senior Member
  • PipPipPipPip
  • 607 posts
Posted Yesterday, 06:58 AM
Sounds like you've got a pretty good handle on things!
Datsun=Project
#166 MaxChlan
MaxChlan
    Advanced Member
  • Members
  • PipPipPip
  • 175 posts
Posted Yesterday, 07:11 AM
I'm hoping so!! My nickname is struggles so you never really know. Sometimes I do well, other times it takes me 20 minutes to remove a hose. Ya never know which one you're gonna get. They didn't teach me anything about cars in my accounting classes  :rofl:
#167 captain720
captain720
  • Senior Member
  • PipPipPipPip
  • 607 posts
Posted Yesterday, 07:15 AM
Hey those lower rad hoses are really awful to remove, now I just pull the radiator and leave the hose on then replace hose outside of car. 😂
Datsun=Project
#168 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,611 posts
  • Cars:1966 520, 1967 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted Yesterday, 12:54 PM
You are correct about the bottom radiator hose on the 720.
