the pile o' parts wagon
It's been a busy couple months, been able to do a few things.
1897E0F3-8D1A-4D49-A67F-9A175E3C73CD_zps
started with some rust protection on the lower frame rails
6FCEE75A-404C-4E05-8960-1E23E123B138_zps
Cleaned up the inner wells ( probably  the worst job so far on this thing) then coated in bed liner
1602FC10-64C1-4488-A91F-7339E7AB7DC7_zps
did a bunch of sanding and got under the hood in primer!
84AD370E-F67D-42A1-BD90-A78392912C0F_zps
followed by sanding the primer
B0F31EC2-7E68-4F94-B881-8331867999A4_zps
more sanding followed by beer and masking
1FA7D4BC-D3D9-4AB0-A933-9444FF59742E_zps
A25DF534-6F9A-4900-BC7D-FBD4C7656108_zps
Then got some paint down. It's a Land Rover blue, not perfect, but something I can live with. Now to make new brake lines, clean up all the hardware or get new hardware. Start assembly under the hood to get the engine back in...oh yeah, there's still the rest of the wagon that needs love..
  • Like 7
  • Replies 49
  • 4 weeks later...
Been moving along at a slow pace. Been trying to do one thing a day or one thing a weekend
Started by bolting up the Brake and Clutch masters and making some new line:
536EB955-38CE-4233-9BA7-4D8023C3189F_zps
917217B9-A382-4DF6-B891-1835D648CD3E_zps
Got all lines made at this point, just need to do the one from the firewall all the way to the rear of the car.
Started to work on rebushing the lower arms and such
DE420877-8566-4724-93EF-35965F901CF4_zps
9F129BAB-5C1D-43D3-BE3F-596E46B397B5_zps
got to bolting the suspension back up
E97C79E7-07C3-41AA-B4F2-9C1BE4C6B878_zps
C258D0B9-2812-4396-B16E-883FC500F5BA_zps
and...started to mess around with home brew zinc plating:
0AFE19EC-82FC-4D11-BF4B-0EAB4637C937_zps
CA001076-5F5A-4BBF-8431-648437C870FB_zps
came out all right, I do think I'll need to leave it in the bath for a longer period of time to get the zinc to stick a bit more.
Also got the heater box all cleaned up, but no pictures there, nothing really exciting about that either way. Had a bunch of rain in LA,  these two punks really don't help out when trying to work on the car either:
6693B8A9-F2B0-4CC9-9225-465F38AA03C7_zps
Been a good few weeks, got small thing accomplished, next week I'll be heading to Japan for a week to go to the Nostalgic 2 day show in Yokohama so hopefully I'll come back with some goodies.
Fingers crossed!
Draker, Wagon Jon, I used this recipe: http://thefactoryfiveforum.com/showthread.php?14392-DIY-Zinc-Plating-for-Donor-Nuts-and-Bolts
I use an old computer power supply to run the thing, seems to be doing ok, but could probably sit in the bath for longer periods of time.
Thanks mrbigtanker, you're wagon is amazing!
  • 1 month later...
So not a huge update. Got back from vacation and been putting in a couple of hours a night on the wagon.
First got the hubs put back together with new bearings.
92C9D7B3-4BD7-41AF-BCCF-497C39B82D9D_zps
A9AF89FE-4A19-48A4-8CC3-0D71E69C4560_zps
Got in some new parts and started assemble the front suspension..
F58071EE-D457-4E44-B79E-FB8FF6D380B6_zps
0E0D270D-4361-41E5-8B9C-CD436AF38331_zps
and then this happened:
25357064-A47A-4981-9476-FED3857B159C_zps
installed in the wagon
1CE2A8C3-CB4B-44BD-8D47-95786B1D9CED_zps
still need to run the lines for the air, was going to put it down on the ground to check stuff, but then realized that my stock steelies won't clear the calipers...so I threw on the Advans to make sure they cleared the calipers
16F383D6-3EBE-45FE-A745-FB893D325047_zps
which leads me into today, all the bolts were rusty on the wheels, so I'm going to see if I can save them
1A97DDBE-3420-4A2A-9C85-523E48C95E1E_zps
got them soaking in some Evaporust, and then I started stripping the red off the wheels
E1BF7209-486A-4C6B-9F2B-D6C53EE38D4C_zps
and of course, since it is a Sunday, and it's hot outside, we must have beer
774FE881-53ED-4E3C-AD9E-5FC75E04CFBC_zps
Cheers all, have a great Sunday
I would love bags on my wagon :( howww
Just joel and filthy both have bags on their cars. They used e30 bmw bag kits. Both builds give a few details about using them.
I'm just curious if this build was done using a different set.
lol sorry guys. got a little busy yesterday. Bags are Universal Aero Sport bags. I pretty much used the Green Goon's idea on the front bags. Bottom mounts were made using their bracket kit. Top hat has bought off ebay, and machined to fit the the T3 coil over top hats. I haven't had the chance to put the car back on the ground to check to make sure all plays well together, but from what I was able to cycle on the jack stands, I don't see any issues. Once I clean up the Advans and buy some tires, I'll put it back on the floor and get more photos. But I see that being a week or two away.
  • 4 weeks later...
Been working on the wagon on and off for the past few weeks. Got the wheels somewhat cleaned up:
 705AA411-E2EA-4360-A7D0-B2A27770F3F9_zps
Then got to coating the front section of the floor boards and the firewall with Al's HNR (head and noise reducer)
1D5F40D3-0228-492C-8500-1B63AA5CA919_zps
94B33AA0-2608-42AF-AB19-A72EB00F08CF_zps
Then on top of that got the Rammat:
60BC8435-7B08-4DEF-85B7-94B291EB23D8_zps
6780A4E5-CF25-4893-ACE7-151EF175AF77_zps
I want it to be as quiet as I can get it. =)
Then earlier in the week, with the help of my neighbor, got the motor in!
3D949A6C-1CA8-4D2B-A948-D7F5F912E529_zps
5595E085-D1CA-45D5-8EEC-B35E0D51C8E3_zps
May seem backwards, but I have a small garage to work out of, so I have to do this in sections. Was nice working on the mini in this garage, but the 510's way bigger  :rofl:
so this is all the way up
CA6DC03D-2164-4A66-B26F-8DB333211C5C_zps
and this is down:
5B274E5A-1EC2-40D6-BCE5-3064F415D634_zps
Don't mind the fender, the previous owner started pluggin holes. I'll eventually get to the body, but for now I flipped the wagon around in the garage to figure out what to do with the rear suspension:
52A3EC1C-C781-49F8-9FF1-5A50A5412DE0_zps
small updates, but slowly chipping away at it.
Inspirational. I need to get mine on the front burner again.
The half moon curved chrome trim is for the rear of the cargo window. Don't see the rest of the chrome trim, but they are the finishing pieces.
The fragile plastic hatch cover is NLA, but I may have a good piece available I repaired and has a good lamp.
I will be fitting LEDs in mine as the stock bulb frequently melted the housing.
Experimental Engineering makes idler arms bushings that make a huge difference, as will a steering box bracket.
  • 3 weeks later...
Been a couple weeks, not much of an update, sitting around waiting on parts and doing little things:
Started with getting fuel tank out, the gas inside of it was completely brown and I was really worried it was rusty inside. But luckily for me everything inside was super clean
2D25208F-BB7F-4086-940C-34498BFCB19C_zps
Couple nights later, I was able to pull the rear end.
[/url]
I think I'm going to run the stock rear end. I was debating on all the options of other rear ends, but that'll just snowball and I know where that'll lead me...soo....
D9CAAB9C-3781-4F56-BD2A-FD9FC92C13E7_zps
Ain't no turning back now!
90D32C0B-38DA-4087-9195-A82000E1A3CD_zps
Got underneath the wagon and started doing some surgery on brackets and such
ABEDEB61-30CC-4538-8AD7-FE45A5AAF079_zps
Now time to clean the underside today. I'm really not looking forward to this
ACC0386E-A5BC-4FDF-8D0E-AB7914E5327C_zps
On a high note, I did get a package the other week:
0488FD11-CDCF-4116-AC2D-1B65B086A404_zps
Met a guy in Japan while at that Nostalgic Car show in February, got to talking and he had one at his shop. Couple months later and agreeing on a price, got me my grille. =) gotta clean it all up, but that's months and months from now!
