521Symmonds Posted August 7, 2016 Report Share Posted August 7, 2016 Is a 620 drum brake spindle interchangeable into a 521? I'm having zero luck finding a replacement so far. I can probably get the origional re machined but I'd save that as my last option. Quote Link to comment
DanielC Posted August 7, 2016 Report Share Posted August 7, 2016 A big change between 521 trucks, and 620 trucks is that 521 trucks use SAE "American" measurements, but 620 trucks are Metric. A 620 brake drum will work on a 521, and the other way around. A 620 rear brake cylinder will bolt on to a 521 rear brake plate, but you will need to use M8-1.25 nuts, and a M10-1.0 flare nut instead of 5/16-24 nuts and 3/8-24 flare nuts. The frame of a 620 has many of the same sized parts as a 521, especially earlier 620 trucks, but again, use metric fasteners. The 620 spindle may fit, but you may have to modify holes to the next larger metric size. But look for a 521 part first. 521 trucks also pop up in junkyards on occasion. Being you are in Port Angeles, Wa, and Datsuns are common on the west coast, I would think you could find a 521 spindle fairly easily. I do not know if you have enough posts to be able to access the classifieds, yet. Try sending a PM to the guy putting a 521 body on a 720 frame. Other members doing frame swaps might also have the parts you need Quote Link to comment
521Symmonds Posted August 7, 2016 Author Report Share Posted August 7, 2016 Thanks for the heads up, I was hoping that they had matching kingpin sizes to just do a quick swap. Unfortunately I live in boston now and 521's have been hard to come by. Quote Link to comment
datzenmike Posted August 7, 2016 Report Share Posted August 7, 2016 Wrong coast? Datsuns are as rare as rocking horse shit out there. Contact Mklotz70 for info. I believe the 521 has an extinct bearing unique to it. If the 620 spindle was a swap 521 owners would do it to avoid the bearing problem. (just guessing here) Send him a private message... http://community.ratsun.net/user/11-mklotz70/?tab=reputation Quote Link to comment
banzai510(hainz) Posted August 7, 2016 Report Share Posted August 7, 2016 Mike and ted down by Olympia have some parts. Im know Ted sold mike a few sets of 521 spndals. Im sure one of those 2 have spare hubs. Quote Link to comment
