angliagt Posted July 31, 2016 Report Share Posted July 31, 2016 Finally pulled the cover off of the '78 B210,& got the brakes & clutch slave cylinder bled. Now,onto installing the rebuilt carb/manifold assembly. Can someone tell me if all of the washers/nuts are the same for all eleven studs on the head? And are the five large spacers all the same thickness? I have one that's not as thick as the others. Thanks in advance. Quote Link to comment
datzenmike Posted July 31, 2016 Report Share Posted July 31, 2016 The studs and nuts are all the same. Those 4 washers that bridge across intake and exhaust flanges (bottom row) are all the same although thickness isn't that important just as long as thick enough to hold both flanges. They are called yokes. 2 Quote Link to comment
angliagt Posted July 31, 2016 Author Report Share Posted July 31, 2016 Thanks! Nice to know that there's just 4 yokes,instead of 5. The 5th one came from who knows where. This is what happens when you don't get back to things that you took apart years ago.I need to follow my own advice........ 1 Quote Link to comment
G-Duax Posted July 31, 2016 Report Share Posted July 31, 2016 Nissan calls them 'Trunion washers'. Quote Link to comment
angliagt Posted August 2, 2016 Author Report Share Posted August 2, 2016 And now to reinstall it - not looking forward to the bottom mounts. Any tips? Quote Link to comment
datzenmike Posted August 2, 2016 Report Share Posted August 2, 2016 Swivel head socket? Quote Link to comment
JDOM310 Posted August 3, 2016 Report Share Posted August 3, 2016 hey fellas i recently had my carb rebuilt for my 80 210 and was felt like replacing the master cylinder. Is it pretty straight forward bolt on and off ? anyone know if there is a thread with a step by step on this? thank you fellas Quote Link to comment
JDOM310 Posted August 3, 2016 Report Share Posted August 3, 2016 also has anyone recently ordered parts directly though pitroad japan? Quote Link to comment
datzenmike Posted August 3, 2016 Report Share Posted August 3, 2016 hey fellas i recently had my carb rebuilt for my 80 210 and was felt like replacing the master cylinder. Is it pretty straight forward bolt on and off ? anyone know if there is a thread with a step by step on this? thank you fellas also has anyone recently ordered parts directly though pitroad japan? Actually this is angliagt's post about manifold fasteners. It's a little out of place to 'barge in' and ask questions about something unrelated. If you would please, by all means start a post on this so that all replies are for you and not confused with someone else. It will also help the forum search engine find info about your topic, and you'll have less trouble trying to find it too. It's really easy, just go to the B-210 forum ... http://community.ratsun.net/forum/46-b210/ and look over on the upper right. There is a black rectangle with START A NEW TOPIC. Click on it and fly at it. Don't forget a title that helps define what you want. Simply saying 'HELP' as a title means everyone has to open it to find out what. B-210 Master Cylinder Mounting Qs would do. Quote Link to comment
JDOM310 Posted August 3, 2016 Report Share Posted August 3, 2016 Thanks mike for the help thought I was on right post just looked and it was started on "slave cylinder " . Heard you were very welcoming didn't know I was barging in . Thanks guys Quote Link to comment
datzenmike Posted August 3, 2016 Report Share Posted August 3, 2016 Tried not to sound like a dick, hope that came across. Please start a post about your master cylinder so we can help you out. We have lots of 210 owners here who have done this I'm sure. Quote Link to comment
angliagt Posted August 7, 2016 Author Report Share Posted August 7, 2016 Well,FINALLY got it back together - what a job! I found out that if you use a plastic straw,you can get the hard to reach spacers/washers to go on,after dropping many on the floor. These are the four on the bottom,the really hard to reach ones. It also really helps to have the metal heat shield,& the metal tube off,before you reinstall it on the car. Quote Link to comment
