Lozer Posted July 30, 2016 Report Share Posted July 30, 2016 Anyone out there know if there is a difference in the length between these? Im doing my ka swap and wondering if I will need to get a new driveshaft cut. Quote Link to comment
EastBay521 Posted July 30, 2016 Report Share Posted July 30, 2016 you do have to get it cut. I forget how much though Quote Link to comment
datzenmike Posted July 30, 2016 Report Share Posted July 30, 2016 There are the shorter 71C from the D-21 Hardbody around 30-32" and then there's the 71Cs from the 240sx which are 34"???inches long. I would love to have one to measure. The zx 5 speed is 31.5" long. 2 Quote Link to comment
scooter Posted July 31, 2016 Report Share Posted July 31, 2016 The d21 tranny is about an inch to inch and a half longer than a dogleg Quote Link to comment
datzenmike Posted July 31, 2016 Report Share Posted July 31, 2016 Assume the N American dogleg as there are imported ones out there that are the same length as the 71B. I have one. This would make the D21 about 27 to 27 1/2" long then. I would have thought closer to 30". Quote Link to comment
scooter Posted August 2, 2016 Report Share Posted August 2, 2016 The d21 tranny is about an inch to inch and a half longer than a 1977 datsun s10 200sx dogleg 5 speed transmission Quote Link to comment
scooter Posted August 2, 2016 Report Share Posted August 2, 2016 I'll measure it again for ya tomorrow, looking at pics I can't decide if that's the total length now or if that's just how much farther back the tranny mount is Quote Link to comment
jesusno2 Posted August 2, 2016 Report Share Posted August 2, 2016 240 trannys are really long. Im using a D21 trans in my 210 and the shifter was almost in the same spot as the stock A series 5spd. I measure the 240 ka trans once i forgot how long it was for some reason i remember the 240 shifter being like 9 inches farther back than the A series. Quote Link to comment
Phixius Posted August 2, 2016 Report Share Posted August 2, 2016 Tranny measurements. .. (mine, so maybe to spot on, but damn close.)Bell to dust shield..S14 KA -- 33 1/2"Longtail (L) 5spd -- 31 1/4"Track KA/Z24 30 1/2"Bell to output shaftsS14 KA -- 33 5/16"Longtail 5spd (L) -- 31 1/2"Truck KA/Z24 -- 29 15/16"Shifter hole locationS14 KA -- 31 1/2"Longtail 5spd (L) -- 29"Truck KA/Z24 -- 26" I should go back a measure with a straight edge... 3 Quote Link to comment
Lockleaf Posted August 2, 2016 Report Share Posted August 2, 2016 The truck trans, I'm assuming that's a d21 2wd? 1 Quote Link to comment
datzenmike Posted August 3, 2016 Report Share Posted August 3, 2016 Tranny measurements. .. (mine, so maybe to spot on, but damn close.) Bell to dust shield.. S14 KA -- 33 1/2" Longtail (L) 5spd -- 31 1/4" Track KA/Z24 30 1/2" Bell to output shafts S14 KA -- 33 5/16" Longtail 5spd (L) -- 31 1/2" Truck KA/Z24 -- 29 15/16" Shifter hole location S14 KA -- 31 1/2" Longtail 5spd (L) -- 29" Truck KA/Z24 -- 26" I should go back a measure with a straight edge... YES!!! The 71B is precisely 31.5". Stand the tranny up on two chunks of 2x4. Place a straight edge across the output and measure down vertically to the front edge of the bell. Tape must be parallel with the center line of the transmission. A sloping measurement is always longer. 1 Quote Link to comment
Phixius Posted August 3, 2016 Report Share Posted August 3, 2016 Ok. Straight edge. And removed dust shield... S14 ka -- 33 5/16. Shaft sunk in 1/8. 33 3/16 for shaft. Ka D21 and 720 z24? -- 28 9/16. Also 1/8 sunk in for shaft. 28 7/16. 2 Quote Link to comment
datzenmike Posted August 3, 2016 Report Share Posted August 3, 2016 Dude........ t/y. 1 Quote Link to comment
scooter Posted August 3, 2016 Report Share Posted August 3, 2016 your on it! good job phixius, how does the bell to tranny mount distance on the d21 tranny look like vs the z 5 speed? if we have the tranny mount distances on here we could pin this maybe? 2 Quote Link to comment
]2eDeYe Posted August 4, 2016 Report Share Posted August 4, 2016 Very nice! Now how about bell to transmission mount center line? :D 1 Quote Link to comment
Phixius Posted August 5, 2016 Report Share Posted August 5, 2016 Well, aren't you guys a needy bunch... Bell to trans mount center line.. L 5spd -- 21" S14 -- 22 1/4" 2wd truck ka -- 22 1/8" There is some wiggle room with the mounts. They have big holes. Didn't take the s14 mount off, so they might be the same. 1 Quote Link to comment
