Stoffregen Motorsports Posted May 16, 2019 Report Share Posted May 16, 2019 Was hoping to hear a progress report. I do love your truck. 2 Quote Link to comment
dat nasty Posted July 15, 2020 Author Report Share Posted July 15, 2020 Turned in the company truck, back the daily 6 Quote Link to comment
dat nasty Posted August 10, 2020 Author Report Share Posted August 10, 2020 Was riding too low, hit a steel plate in the road. Bent my front radius supports, crossmember for the control arm and the lower control arm. Still drives, just not the straight arrow it was. Going to cut the frame at the firewall narrow and make my own triangulated fronts... Bigger and better things coming. also in the long run looking to redo my back half, links are fine but I want the bags over the lower link instead of the axle 2 Quote Link to comment
dat nasty Posted August 12, 2020 Author Report Share Posted August 12, 2020 Haven't really seen what she can do yet in fear of my license. at 107 it still has some walk on 185/55-14. Plenty of power. fairly smooth considering the recent damage 4 Quote Link to comment
dat nasty Posted March 21, 2021 Author Report Share Posted March 21, 2021 (edited) Cheaped out on an alternator and after a month it overcharged. Fried my battery, alternator, starter, a couple relays and my air compressor. Swapping in a gm 3 wire and a York ac pump for air. Should be back up by summer. Edited March 21, 2021 by dat nasty 1 Quote Link to comment
banzai510(hainz) Posted March 22, 2021 Report Share Posted March 22, 2021 if battery fryed cause the external volt reg is bad. Get a good one or your IR alternator the internal VR is bad(if you used the jumpers to convert to IR tyep alt 1 Quote Link to comment
datzenmike Posted March 22, 2021 Report Share Posted March 22, 2021 How would it fry the starter. It's only over charging when running the engine. Battery can only hold 12v no matter how over charged it is. 1 Quote Link to comment
dat nasty Posted March 22, 2021 Author Report Share Posted March 22, 2021 No more external voltage regulator, internally regulated alternators for the ka. It stopped charging for a few minutes and then ran 18 volts for a while and then nothing worked. Pretty sure it had been doing it throughout the day without me noticing because I did notice my starter had been making funny sounds. Starting over with all new components, bigger and better. Eliminating the electric air compressor for a belt driven. 1 Quote Link to comment
dat nasty Posted March 22, 2021 Author Report Share Posted March 22, 2021 4 minutes ago, datzenmike said: How would it fry the starter. It's only over charging when running the engine. Battery can only hold 12v no matter how over charged it is. Don't know. drove the truck around most of that day. Started it a half a dozen times, sometimes super slow to start. Sometimes just really loud. On the way home at night I realized my lights really really bright. Looked down and it was 18.3 volts. Truck started shutting off and turning on as I was pulling over and then stopped charging completely so I limped it home. New relays, new battery, everything else unhooked. Starter sounds like a ratchet. Even straight jumped. 1 Quote Link to comment
dat nasty Posted July 18, 2021 Author Report Share Posted July 18, 2021 Viair 400c air compressor burnt up. Pretty sure that's been my electrical problem. Brushes melted and locked up. didn't blow a fuse though. I had taken it apart and inspected it while the truck was down and it all looked good. Picked up a pair of 444c to replace it. Thanks to a fellow mini trucker who sold me his. Little worried about the used tranny I put in a couple years ago but she's been going strong as my daily driver 2 Quote Link to comment
