Fuel pressure regulator location?
Rasp933
  • Replies 7
I've never needed one when the return line was used, as long as it's a stock return line that's before the carb.  I've never dealt with aftermarket returns off the carb, as none of my Webers have them.  Stock returns lines are before the carb, and work well with higher volume L20B type pumps as well as stock-type electric pumps as long as the pressure is below 7PSI.
In either case it would have to be before the carb.  It's the float needle valve on a Weber that's highly sensitive to overpressure, as it doesn't take much to force the valve open.
The cheapo deluxe regulators are designed to be used in the return line. If used in the feed line, they restrict fuel flow.
The best regulator is a low pressure unit from Holley. The cost about $40 and have provisions for a gauge. They are easily adjustable and do not restrict fuel flow.
Here's a Holley setup in a 510. I also bent custom hard lines from 3/8 stainless tubing and used -6 AN fittings everyhwere.
