spdcrazy Posted July 11, 2016 Report Share Posted July 11, 2016 I just tore apart my 521 hub and spindle assembly, problem is, I do not see a wheel seal at all?!?! does the seal fit inward of the inside bearing? and over the spacer? if not, where? and just to make sure i'm not missing anything else, when I took mine apart, i removed the cap, I removed the cotter pin, took off the spindle nut, and the key'ed flat washer. then the hub slid off and off came the outter and inner bearings. spacer of course is still attached to the spindle. am i missing anything else? 1 Quote Link to comment
Rick-rat Posted July 11, 2016 Report Share Posted July 11, 2016 Should be on the back side of the hub behind the inner bearing 1 Quote Link to comment
spdcrazy Posted July 11, 2016 Author Report Share Posted July 11, 2016 so sandwhiched between the spacer and inner bearing? 1 Quote Link to comment
Rick-rat Posted July 11, 2016 Report Share Posted July 11, 2016 Do you have a pic of the hub and spindle 1 Quote Link to comment
Rick-rat Posted July 11, 2016 Report Share Posted July 11, 2016 If the inner bearing does not fall out, then the seal is holding it in 2 Quote Link to comment
spdcrazy Posted July 11, 2016 Author Report Share Posted July 11, 2016 not of mine, and i'm on a work computer so i can't post any. there is a thread that shows the spacer (google 'front wheel bearing options ratsun' its the first link) and bearing but i have yet to find a photo of the seal installed. 1 Quote Link to comment
spdcrazy Posted July 11, 2016 Author Report Share Posted July 11, 2016 my bearing fell right out. is the OD of the seal suppose to fit into the ID of the inner part of the hub? 1 Quote Link to comment
Rick-rat Posted July 11, 2016 Report Share Posted July 11, 2016 Yes, maybe the seal is still on the spacer 1 Quote Link to comment
spdcrazy Posted July 11, 2016 Author Report Share Posted July 11, 2016 spacer is bare, so it doesn't exist on mine! which is ok, the seals are obtainable, just wondered where exactly it fit. the hub spun freely and i have had no issue for the last year (since i bought the truck) its almost a daily driver. 1 Quote Link to comment
mklotz70 Posted July 11, 2016 Report Share Posted July 11, 2016 You can see the seal in the hub http://www.bluehandsinc.com/uploads/4/4/3/5/4435437/1403282_orig.jpg 3 Quote Link to comment
spdcrazy Posted July 11, 2016 Author Report Share Posted July 11, 2016 gotcha! thanks rick-rat. i appreciate talking with me about it. mklotz, i knew you would have the answer, just didn't want to bother you. yet again. also i figured if i couldn't find a photo, someone else might aid from my question. Thanks all! 1 Quote Link to comment
mklotz70 Posted July 11, 2016 Report Share Posted July 11, 2016 no prob. You can download the factory manuals at several locations online. http://www.bluehandsinc.com/manuals.html 2 Quote Link to comment
