zx diff into 510
Hey,gotta 72 510 & planning on maybe finding a donor zx (79-83) to upgrade struts,brakes, transmission. What has to happen to also use the differential in the 510? And could you tell me what the gear ratio would be in a zx ? I think turbo cars were different from non turbos
  • Replies 10
Well I'm not sure if I'll need the 510 diff rebuilt, I know it's leaking, if it's OK I will use it. But if I get a zx donor car ,I'll have the zx diff on hand.The 510 isn't drivable, so I don't know if it's bad. Anyone know if parts are available to rebuild one, or if it can be rebuilt for under say,$400.? Bought the car not running, so don't know if the diff is gonna be noisy or messed up.
True if it's an R200, but if the diff is a R180, it's a direct swap if the spline count is the same and it's a bolt in flange axle.
280ZX
'79 4-speed R180 3.36 Ratio 25 spline
79 5-speed R180 3.36 ratio 25 spline
79 4-speed R200 3.36 ratio 2+2 29 spline clip in
79 5-speed R200 3.70 ratio 2+2 & GL 29 spline clip in
79 automatic R180 3.54 ratio 2+2 and Coupe 25 spline
80 5-speed R180 3.54 ratio 25 spline
80 5-speed R200 3.90 ratio 2+2 and GL 29 spline clip in
80 Auto R180 3.54 ratio 2+2 and coupe 25 spline
81-83 5-speed R200 3.54 All Turbo 29 spline clip in
81-83 5-speed R200 3.900 ratio All naturally asperated 29 spline clip in
81-83 automatic R180 3.54 ratio all naturally asperated 25 spline
