scooter Posted July 1, 2016 Report Share Posted July 1, 2016 I dont but i can take a picture the next time i check the lash.. I wanna pull a couple pads off and see if there has been any wear inside the cup Quote Link to comment
scooter Posted July 1, 2016 Report Share Posted July 1, 2016 This is what you get when you put big valves in.. I dont think this would even work on an l20b as i had to cut alot of chamber wall out. Im also bored to 89mm. Quote Link to comment
datzenmike Posted July 1, 2016 Report Share Posted July 1, 2016 A 44mm valve is only 4.5mm wider towards the cylinder wall than an L20B's 35mm intake valve. That's only 0.177". These 44mm valves fit an L28 cylinder and it's only 0.5mm (0.020") wider bore than an L20B. They'll fit a stock bore L20B no problem. 1 Quote Link to comment
banzai510(hainz) Posted July 1, 2016 Report Share Posted July 1, 2016 I think only on the L16s you have to notch the bore for the bigger valves( what I read) key is the gasket bore size!!!!!!!! Quote Link to comment
scooter Posted July 1, 2016 Report Share Posted July 1, 2016 Those are 45 and 36's.. Think theyd clear the block of an l20b with .600 lift? ;) Quote Link to comment
datzenmike Posted July 1, 2016 Report Share Posted July 1, 2016 Yes to clearing the block. Quote Link to comment
