KoHeartsGPA Posted June 24, 2016 Report Share Posted June 24, 2016 So I dug mine up, saw signs of leaks on it, tested it and found one leak, I'm wondering if this part is available or what other datto can I salvage this from IF lucky enough to find a good one at JY... Quote Link to comment
datzenmike Posted June 24, 2016 Report Share Posted June 24, 2016 Core? or heater valve. A rad shop can solder the core up. Hell most people probably could. It's not like it's been hit by a rock. Probably at a pipe joint. The valve, or water cock, is likely just the seal. If you take your time, it can be taken apart at least once as brass parts must be bent and then bent back into place. http://community.ratsun.net/topic/16631-stop-heater-valve-leak/ http://community.ratsun.net/topic/10273-fix-510-heater-controle-valve/ 1 Quote Link to comment
KoHeartsGPA Posted June 24, 2016 Author Report Share Posted June 24, 2016 Yeah the valve leaks, I was wondering about taking it apart, I'll do it and see what's up, thanks Mike! Quote Link to comment
KoHeartsGPA Posted June 25, 2016 Author Report Share Posted June 25, 2016 Ratsun is awesome!, quick search yielded this gem, and for others with this issue, here's your under $1 fix... http://community.ratsun.net/topic/16631-stop-heater-valve-leak/ Quote Link to comment
