1973 Datsun 620 speedometer
Angel_Legion
  • Replies 20
WTF!!!!!!!!
2 things  does the odemeter still turn if the nnedle don't move. Then the cable is fine . Otherwise the cable is most likely broke.
you have to pull the instrument cluster and unscrew the cable at the trans. most times they break near the trans and you can pull right out.
see if a cable is avail from Nissan. I use a generic square cable but learn how to fix this over time.  But I bought spare 521 cabel and just ezer to install quickly.
Yes, if odometer is still turning the cable is fine and the problem is the gauge itself. Remove the gauge cluster by loosening it forward and reaching up behind to unscrew the cable. Take a look, can't hurt and you may find the spinning cup that turns the needle by magnetism is stuck, or jammed. Try and fix.... or replace with another. Only real source for one will be from a junked 620 or try our classifieds for a member that has one.
Otherwise the cable is the most likely cause. They are easily caught on road obstructions and torn open. Water and dirt get in and if they don't jam or seize, water freezes them solid in the winter and the transmission just twists the inner cable till it breaks. Visually look for kinks or damage to the cable on the under side of the truck. If the damage is visible go straight to replacing it. Loosen the transmission end with vice-grips and unscrew. the cable should be clipped every few feet to the body or frame to keep it safe, so release these tabs. The gauge end fits through a rubber grommet in the fire wall so carefully pry it out and extract the other end. Replacement is the same as removal. Note that the transmission end of the inner cable has a ferule crimped on that only fits the transmission in one position so that  it turns.
My truck is down with spun rod brgs, so rebuilding, but...my speedo would slowly climb, til I was reading like 100 going 30, I think it rotates all the way around..is there any hope without finding another meter?
  • 2 months later...
Where can I get a 16 tooth speedo pinion or does it have to be 16 ?
If your speedometer was accurate then certainly you need the exact same number of teeth. Things that can affect the speedometer readings are changed differential ratios and larger or smaller diameter tires. I suppose if the transmission was swapped from another vehicle and the pinion wasn't swapped also then it would read wrongly.
32703-22000 is the correct 16 tooth gear only. Besides the early 620 thew 16 tooth gear was also used (among other gear sizes) in the 311 Roadster, 510, 610 and 710s Different numbers of teeth were used to reflect the different differential gears used in sedans and wagons, tire sizes and options. For the '73 620 there was only the 16 tooth used.
Only way for this gear to be crushed is someone twisting it to install or remove. Make sure you slide in straight using the key slot as a guide.
