itsallgood Posted June 17, 2016 Report Share Posted June 17, 2016 i am looking to adjust the valves on my j15 i found this info. http://www.theforkliftengineco.com/nissan-j15-specs.html is the gap i need Intake Clearance .010 hot will this walk threw work for the J15 http://datsun1200.com/modules/mediawiki/index.php?title=Valve_adjustment thanks for any help. 1 Quote Link to comment
datzenmike Posted June 17, 2016 Report Share Posted June 17, 2016 http://www.theforkliftengineco.com/nissan-j15-specs.htm I don't see any valve clearances listed. http://datsun1200.com/modules/mediawiki/index.php?title=Valve_adjustment While the J and the A series are similar and both are push rod they aren't the same. The Haynes 620 repair manual has the J13 engine listed and most likely the valve clearances. 2 Quote Link to comment
itsallgood Posted June 18, 2016 Author Report Share Posted June 18, 2016 would you happen to have the valve clearance? so i don't have to pay for the manual. 2 Quote Link to comment
Charlie69 Posted June 18, 2016 Report Share Posted June 18, 2016 You can find most information on the Internet. Look for manuals in the .pdf format they are usually downloadable for free. 1 Quote Link to comment
itsallgood Posted June 18, 2016 Author Report Share Posted June 18, 2016 You can find most information on the Internet. Look for manuals in the .pdf format they are usually downloadable for free. thank you. found it. pdf was the way. 2 Quote Link to comment
