logicali Posted June 15, 2016 Report Share Posted June 15, 2016 I have a 71 510 coupe and I'm missing bolts to attach my rear end , shock mount bolts , and a bunch of other random rear suspension hardware What car that I could find at the junkyard can I pull the bolts from ??? would a 80s 300ZX ??work would the 280 ZX work ???? I'm pretty sure all the Z cars from the 70s work correct(wont find these at junkyard)?? 1 Quote Link to comment
KoHeartsGPA Posted June 15, 2016 Report Share Posted June 15, 2016 Metric bolts with fine thread....easy pickings, just need to scavenge for the correct size :) Quote Link to comment
Dolomite Posted June 15, 2016 Report Share Posted June 15, 2016 Not to be a dick, however, you have a sedan. The only coupe is a bluebird. 1 Quote Link to comment
KoHeartsGPA Posted June 15, 2016 Report Share Posted June 15, 2016 Dick! :poke: 3 Quote Link to comment
thisismatt Posted June 15, 2016 Report Share Posted June 15, 2016 Are you in Los Angeles? Just look up a fastener supplier, eg fastenal Quote Link to comment
Lockleaf Posted June 15, 2016 Report Share Posted June 15, 2016 I prefer to go to a junkyard and rape a couple cars for bolts. 1 Quote Link to comment
datzenmike Posted June 15, 2016 Report Share Posted June 15, 2016 The 610 sedans will probably work also. Similar IRS cars but slightly larger units are the 240/260/280z/280zx/810 and Maxima. They may not all match but some have to. Oh and the S12 200sx is worth a look. Quote Link to comment
logicali Posted June 15, 2016 Author Report Share Posted June 15, 2016 I prefer to go to a junkyard and rape a couple cars for bolts. story of my life 1 Quote Link to comment
INDY510 Posted June 16, 2016 Report Share Posted June 16, 2016 Find any bolt on your car that needs a 14mm wrench .. that's the size/threads you need for your lower shock mount .. I think it's 10x1.5 and probably $2 at orchard hardware Quote Link to comment
KoHeartsGPA Posted June 16, 2016 Report Share Posted June 16, 2016 It's more fun going to the JY....and you never know what you might find... 1 Quote Link to comment
