logicali Posted June 13, 2016 Report Share Posted June 13, 2016 No pads or rotors but has brackets and calipers anybody know what these came from ??? Quote Link to comment
Hix1985 Posted June 13, 2016 Report Share Posted June 13, 2016 They look like 1982 or 83 280zx calipers 3 Quote Link to comment
INDY510 Posted June 13, 2016 Report Share Posted June 13, 2016 you might want a bolt/washer on that lower shock mount 1 Quote Link to comment
datzenmike Posted June 15, 2016 Report Share Posted June 15, 2016 Totally a guess until I get home... IF it's Nissan equipment.... '82-'82 S110 200sx, Maybe the early S12 with H-190 axle. I'm going to say NOT the zx as the e brake appears to be pulled horizontally from behind the differential. I may be wrong but this would be a solid axle car set up. Quote Link to comment
logicali Posted June 18, 2016 Author Report Share Posted June 18, 2016 do the numbers stamped on the calipers mean anything?..... does anyone know if these kind of brackets will let me use both calipers(200sx or maxima)? i just want to buy new caliperes pads and rotors and move on Quote Link to comment
4perrev Posted June 18, 2016 Report Share Posted June 18, 2016 Might be 200x, but probably maxima brakes. Just bought 86-87 maxima rear calipers to go over 200sx rotors. bought custom mounts from a guy on line for $99. If those are trashed, go new all the way. Not sure your mounts would fit the new ones, but if getting them from a junkyard, it maybe pretty cheap! Quote Link to comment
logicali Posted June 26, 2016 Author Report Share Posted June 26, 2016 Totally a guess until I get home... IF it's Nissan equipment.... '82-'82 S110 200sx, Maybe the early S12 with H-190 axle. I'm going to say NOT the zx as the e brake appears to be pulled horizontally from behind the differential. I may be wrong but this would be a solid axle car set up. my parts store will let me return the parts if they dont what sholuld i try first rotors 82- 200sx or 82 maxima? calipers ??? Quote Link to comment
logicali Posted July 1, 2016 Author Report Share Posted July 1, 2016 The rh one is on the left side and lh one is on the right side , whoever put em on , put em backwards Quote Link to comment
datzenmike Posted July 3, 2016 Report Share Posted July 3, 2016 See that long casting neck sticking out to the left? It holds the parking brake cable? Well the zx does not have that. The '82-'83 S110 does and so does the almost identical '82-'84 Maxima. Quote Link to comment
bilzbobaggins Posted July 3, 2016 Report Share Posted July 3, 2016 They on backwards to get the bleeder on the top? Quote Link to comment
datzenmike Posted July 3, 2016 Report Share Posted July 3, 2016 You mean left side on right. Normally the S110 calipers are mounted to the rear of the wheel not on top like this 510. Thus the bleeder is specific to left or right side in order to be upward for bleeding. In the top position the bleeder will be front or back. Don't know which is best for bleeding. Rotating the caliper mount 90 degrees to the rear would place the calipers in the S110 position but left and right would be more important. Quote Link to comment
bilzbobaggins Posted July 3, 2016 Report Share Posted July 3, 2016 Lulz. Yeah. Side to side. Was my only thought. Quote Link to comment
logicali Posted July 12, 2016 Author Report Share Posted July 12, 2016 does that mean these brackets are on wrong?? would any other calipers fit? Quote Link to comment
]2eDeYe Posted July 13, 2016 Report Share Posted July 13, 2016 you might want a bolt/washer on that lower shock mount This is cracking me up, Mr. 2 lug nut guy... :rofl: Quote Link to comment
