76 fastback Posted June 8, 2016 Report Share Posted June 8, 2016 I said let there be a manual And there was And it was good. And now I say let there be a five speed so it can be better And there will, but first I must ask the question will a five speed out of a 80-83 210 (not a b210 but a 210) bolt directly into the b? And is that a better tranny? And if not what will jump up in there? Quote Link to comment
flatcat19 Posted June 8, 2016 Report Share Posted June 8, 2016 Yes. A series is A series. Quote Link to comment
datzenmike Posted June 8, 2016 Report Share Posted June 8, 2016 Definitely will bolt to the engine, length is the biggest factor so you don't have to modify the driveshaft length. Keep in mind that a 5 speed doesn't make the car go faster it just reduces highway RPMs for a small gain in economy. They are not much of an advantage if you drive primarily in town and don't use 5th much. The 210 had two 5 speeds. Both were 60 series. The '79 was a dogleg (NOT the same dogleg as the B-210) shift pattern while '80 and on was a regular H pattern. Quote Link to comment
Stoffregen Motorsports Posted June 8, 2016 Report Share Posted June 8, 2016 I never really knew which 5 spd I had in my 320 (with an A series), but it was a dogleg. The coolest part about it was the spline count at the input and output, they were much bigger than the standard A series stuff. This is the only picture I have of it. Can you identify this trans, Mike? Quote Link to comment
KELMO Posted June 11, 2016 Report Share Posted June 11, 2016 I think you need to use a clutch set up that applies to the transmission. If I recall correctly, the first time I did this I used an A12 clutch set up. the inside diameter of the disc was smaller than the shaft. Ruined a perfectly good pilot bushing trying to mate the trans and block together. Quote Link to comment
Stoffregen Motorsports Posted June 11, 2016 Report Share Posted June 11, 2016 You're right. I had to mix and match discs and pressure plates to come up with the right combo. but I knew if I looked hard enough, I could have found it in kit form. I just never took the time nor did I care, since I had a working combo. Quote Link to comment
