sBay510 Posted June 9, 2016 Author Report Share Posted June 9, 2016 I would definitely take the top cover off and check all the circuits under there before removing them all together. Although, removing them is not very difficult at all. Here is the 1st part of 2 videos that will show you the carbs being rebuilt. May offer good guides: https://www.youtube.com/watch?v=4dxO1TPWhlE So funny..I've actually watched both part 1 and 2 soooo many times the past 2 weeks. Thanks for the link anyways. Hopefully it will help some other out, or if anyone is interested in Weber sidedraft carbs. It looks like i will just have to at least get the cover off, look around, clean different parts with carb cleaner...on both carbs. I really hope this works out. Quote Link to comment
sBay510 Posted June 9, 2016 Author Report Share Posted June 9, 2016 All carbs benefit from a richer mixture to get started when engine is cold. SU's don't even have an accelerator pump you could use to force a rich condition by repeatedly pumping the gas. The choke on the SUs lifts the jet allowing more gas in. I know these are not SUs but maybe the same thing. This is why I say unlikely both carbs would have a sunken float or common problem. It is strange that both carbs are having the issues. I presume both happen to be clogged up somehwere? Quote Link to comment
4perrev Posted June 13, 2016 Report Share Posted June 13, 2016 Pretty sure you've done this somewhere in the post but, is the fuel pump working? Either that or the float needle is stuck. Quote Link to comment
kmc63 Posted June 14, 2016 Report Share Posted June 14, 2016 Well? Any outcome on this situation? Quote Link to comment
4perrev Posted June 15, 2016 Report Share Posted June 15, 2016 ??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? Like he said /\ Quote Link to comment
sBay510 Posted June 16, 2016 Author Report Share Posted June 16, 2016 Hey guys, apologies for the delay on updates. I'm traveling for work right now and I'll be posting a lengthier update soon but I wasn't able to get it started. Put gas directly into carb bowls to bypass any fuel delivery issues and couldn't get the engine running. Sputtered for a little but wouldn't fully start. Sucks but may have to take into a shop unfortunately due to a time crunch. I'll post details in a day or two Quote Link to comment
banzai510(hainz) Posted June 16, 2016 Report Share Posted June 16, 2016 how do you put gas directly in carb bowls? they going to ream$$$$ you on this. thats if they know what they are even doing. Quote Link to comment
sBay510 Posted June 23, 2016 Author Report Share Posted June 23, 2016 how do you put gas directly in carb bowls? they going to ream$$$$ you on this. thats if they know what they are even doing. I took the carb cover off and filled the fuel bowl with gas directly. Yes, i really do not want to take it to a shop but I am running out of time where the car is currently stored. I need to get the car out of the space within a week. I would really like to fix it myself. I live in Los Angeles and was wondering if anyone has any experience with Mike’s Z Shop in Whittier, or any other reputable shops in LA? I think the problem is that no fuel is squirting out into the barrels. Something must clogged…but on both carbs? I would probably have to take the carbs off and do a full clean through. After I took the carb cover off, I did notice that the accelerator pump circuit rod was stuck on one of the carbs. I fixed that. I took a video and some pics of the car’s setup for you guys to have a reference. Are the accelerator pump circuit rods supposed to move up and down that slowly? I don’t see any fuel squirting out into the chambers. Video: https://drive.google.com/open?id=0B6yb58hHiQOTTm10RFRpQlFld1E (Having issues with the pics) Quote Link to comment
Jesse C. Posted June 23, 2016 Report Share Posted June 23, 2016 Wow! That is a lot of varnish! Best bet is to just have the carbs gone through. 1 Quote Link to comment
banzai510(hainz) Posted June 23, 2016 Report Share Posted June 23, 2016 well dont get the car towed and in the junk yard. Carb clean the jets I guess would be a try never let a car sit too long!!!!!!!!! 1 Quote Link to comment
sBay510 Posted June 23, 2016 Author Report Share Posted June 23, 2016 Wow! That is a lot of varnish! Best bet is to just have the carbs gone through. Yea, the carbs will probably have to get a good cleaning. Varnish? Do you mean on the Good luck. :crying: Thanks well dont get the car towed and in the junk yard. Carb clean the jets I guess would be a try never let a car sit too long!!!!!!!!! No plans for a junkyard that is for sure. I need to tow to a shop, or a different storage location. Yes, never let the car sit too long without starting it! I any case, what are your guys' opinions?? Debris stuck somewhere in the carbs? There is supposed to be fuel squirting into the barrels correct? Quote Link to comment
sBay510 Posted June 23, 2016 Author Report Share Posted June 23, 2016 Some pics of the car's setup [/url]">http:// [/url]">http:// [/url]">http:// [/url]">http://http://s1064.photobucket.com/user/kanzdj1/media/510/20160619_193556.jpg.html'> 1 Quote Link to comment
banzai510(hainz) Posted June 24, 2016 Report Share Posted June 24, 2016 Maybe aim looking at this wrong but the rear carb the four slotted thing I assume are the jets. Are they to be screwed in . Mine alwasy back out and have issues( I can still start). Unless you back them off to clean them out. How long you had this sitting again? I really dont know much about webers DCOES hate for you to tow it soem assholes ruin cars buy getting them towed. You got a nice setup Quote Link to comment
