sleeperlee Posted June 5, 2016 Report Share Posted June 5, 2016 hay , is transfering engine & trans from a 720 napz to a 1972 510 gonna be a fairly easy swap? Quote Link to comment
datzenmike Posted June 5, 2016 Report Share Posted June 5, 2016 Define fairly easy. The 720 has two different transmission lengths. If 26" long then it's the same length as the stock 510. Otherwise you have a 31.5" long one and will need a modified driveshaft. (not much info... the length is for the sedan, the goon is different) Cut to about 37 3/8" long. In either case the rear cross member will need looking at for fit. The Z ??? you don't have much info on the year or engine. Has the carb over on the right side and it's operated by cable. The 510 is on the left and uses linkage so you're going to need something done there. The Z series trucks have a 'rear sump' that won't fit where the 510 needs a front sump pan. You will need a larger rad for a larger engine. The Z?? exhaust is on the same side but you will have to mate it to the 510 system The 510 uses an external regulator. With a few mods you can keep your internally regulated alternator. Try the Z engine brackets, the 510 are for an L series engine and won't work for you. The rubber isolator mounts?? don't know the 510s' may work or maybe the Z ones. 510 speedometer will fit the 720 transmission pinion sleeve Quote Link to comment
Lockleaf Posted June 5, 2016 Report Share Posted June 5, 2016 See my thread. http://community.ratsun.net/topic/66801-a-goon-called-half-pint-the-brutal-beginning-71-510-wagon/p?=1269361 It covers everything I have done to fit a z22 from an 82 720 in to my 71 510 wagon. Most of the info is on the last 3 pages or so, but info is scattered throughout. But the basics - 510 rubber engine mounts. L series engine block brackets, reversed side to side. Remove entire hood prop and bracket. Install/build cable throttle pedal and throttle cable. Custom oil pan (or flip crossmember for front sump and find an early 80s car Z series oil pan) Trans crossmember drop brackets (if long trans). Modified transmission mount (or possibly try using a 510 mount). Cut body for new shifter location (if using long trans). All of this is covered in fair detail in my build thread. Quote Link to comment
sleeperlee Posted June 5, 2016 Author Report Share Posted June 5, 2016 Thanks for the info ,in research stage right now. Quote Link to comment
datzenmike Posted June 5, 2016 Report Share Posted June 5, 2016 It's certainly do-able. Some things like the throttle cable and exhaust are custom and up to you how you do it. What engine??? A Z24 is a torque monster and only fitted to heavy trucks and a Van. Quote Link to comment
Stoffregen Motorsports Posted June 5, 2016 Report Share Posted June 5, 2016 I don't think it gets much easier than that. All old Datsuns are pretty flexible designs and lots of parts from many other years of Datsun and even Nissan vehicles will fit, but you can't expect everything to bolt in. There will be some fabrication involved. Quote Link to comment
sleeperlee Posted June 5, 2016 Author Report Share Posted June 5, 2016 Thanks, 720's seem to still be out there with good running motors & 5 speeds ,so l Figured it might be a pretty simple donor vehicle for fairly inexpensive 510 project, if the deal I'm working on comes through, your input is very helpful.Thanks. To bo continued,hopefully. Quote Link to comment
banzai510(hainz) Posted June 5, 2016 Report Share Posted June 5, 2016 find a L20 make this ez Quote Link to comment
sleeperlee Posted June 6, 2016 Author Report Share Posted June 6, 2016 Some 720 trucks have L20 engines too right? It would be nice to find a running donor vehicle with a5speed. Quote Link to comment
Lockleaf Posted June 6, 2016 Report Share Posted June 6, 2016 Only 1980 was L powered in the US. Quote Link to comment
