B210ratsun Posted June 16, 2016 Report Share Posted June 16, 2016 I have the T3 coilovers for the front, and for the rear I cut the springs. I wanted to ask will the front lower control arm or tension control rods all from T3 for the datsun 510 fit my 81' 210? Pics... Quote Link to comment
B210ratsun Posted June 16, 2016 Report Share Posted June 16, 2016 Last pic is my master, 280z not ZX master. The size and mounting position are different from one another. I used the OE B210 master which I think is the same as your OE master, before swapping the rearend for a 510 wagon rearend. Once I did the swap I needed more pedal. In case it's not clear I have T3 280zx front coilovers. Quote Link to comment
OmahaJames Posted June 21, 2016 Report Share Posted June 21, 2016 Last pic is my master, 280z not ZX master. The size and mounting position are different from one another. I used the OE B210 master which I think is the same as your OE master, before swapping the rearend for a 510 wagon rearend. Once I did the swap I needed more pedal. In case it's not clear I have T3 280zx front coilovers. So you are saying that with just the 280ZX front brakes you are able to get by with the B210 master cylinder? Quote Link to comment
B210ratsun Posted June 23, 2016 Report Share Posted June 23, 2016 I did on a rebuilt one. I would actually prefer that pedal feel to what I have now. 1 Quote Link to comment
