Stereo noob q's
Real quick to begin with I have a 620 sc I want to install new wire for a amp and a radio. just wondering what gauge you guys used and did any of you guys use a 1 to 2 fusible box to power both...
I'm going to install 4 inch jbls and two 8 inch JLs
Another thing my truck doesn't have wire harness should I install a switch so I won't drain my baterry
Thanks guys
  • Replies 3
Wire the radio to the accessory side of the fuse box.
Usually the radio tells the amp to turn on so a switch isn't necessary. You will need a heavier cable for power to the amp. This cable must have a fuse at the battery end.
Accessory will turn on/off with the key.  This way you don't have to remember to turn it off. Most units have a send wire to the amp to tell it to turn on when it does. This way everything shuts off with the key.
