720inOlyWa Posted May 24, 2016 Report Share Posted May 24, 2016 Well the big day has finally arrived. I am pulling an engine / transmission out of my ‘donor truck’ to rebuild for my daily driver. (see My 720 resto). I have big plans to renovate the engine. I have never balanced a motor and I intend to do that with this one, just to see what happens. From the driveline right through the pressure plate and internals, I want to optimize my ZS-24 before swapping it into my daily. But aside from balancing, it will get a total rebuild from top to bottom. I like the stock motor. It seems pretty well matched to me. It isn’t the little burro that my L-20b was, but it seems to work fine. I suppose another few horsepower would be okay, but I am not willing to sacrifice much mileage or driveability for it. What I want to know is if there is anything inherent in the engine design that I should address since it will be all apart anyway? Is there anything that you would recommend to someone who is zero timing one of these engines? Is this the time to switch out to a fuel injection system? any mild mod options you care to share? Thanks! Quote Link to comment
Spiff Posted May 24, 2016 Report Share Posted May 24, 2016 Yes. Definitely go fuel injection, I converted mine using parts from a z20e. It runs really good. Z20e parts are hard to find though, that's the downside of it. Quote Link to comment
datzenmike Posted May 26, 2016 Report Share Posted May 26, 2016 Nissan did a good job of balancing their engines, If just replacing the rings and bearings you really don't need it. 1 Quote Link to comment
