Speedracer906 Posted May 24, 2016 Report Share Posted May 24, 2016 I have a U67 block of unknown origin and when I guessed the year and vehicle for ordering the Sealed Pro gasket set, I ended up with the wrong oil pan gasket. Can anyone help me figure out witch U67 block I have so I can order the correct oil pan gasket?My U67 Block and the Sealed-Pro oil pan gasket [/url]">http://The oil pan on my U67 block [/url]">http://s733.photobucket.com/user/speedracer906/media/IMG_6037.jpg.html'>Note the narrowness of the two center front pan screws.. Thanks Y'all! Quote Link to comment
hobospyder Posted May 24, 2016 Report Share Posted May 24, 2016 U67 is a head. Should say L16 L18 or l20 on it above spark plug #4 on the block not the head. That will help determine what year and model it came out of 1 Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 Like hobo said... Oil pan should always match vehicle...all the gaskets should still be the same between the L4s. On block, below spark plug #4 is engine code. I'm guessing you have an L20B. Run yourself down to AutoZone and get the right gasket. 1 Quote Link to comment
DanielC Posted May 24, 2016 Report Share Posted May 24, 2016 Wrong gasket. You can get individual gaskets at Nissan. I believe all L-16, L-18 and L-20-B engines use the same oil pan gasket. 1 Quote Link to comment
hobospyder Posted May 24, 2016 Report Share Posted May 24, 2016 So, what year make and model did you say when you bought the gasket? Quote Link to comment
Doctor510 Posted May 24, 2016 Report Share Posted May 24, 2016 Looks like a CA20 OP Gasket Quote Link to comment
Speedracer906 Posted May 24, 2016 Author Report Share Posted May 24, 2016 It's an L20B, its odd that the U67 # is on the block. As far as I know the pan is correct with the block. I'm at Napa to see what they show in images of there pan gaskets. Yes, I like Great Stuff gasket goo! I asked for a 78 L20 gasket set. Quote Link to comment
Speedracer906 Posted May 24, 2016 Author Report Share Posted May 24, 2016 NAPA shows a gasket that looks right, I'm going with the idea that I ended up with a CA20 pan gasket or something like that. Any idea what pan this is, car, truck etc? Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 It's an L20B, its odd that the U67 # is on the block. As far as I know the pan is correct with the block. I'm at Napa to see what they show in images of there pan gaskets. Yes, I like Great Stuff gasket goo! I asked for a 78 L20 gasket set. Are you sure it doesn't say U67 on the cylinder head; near the #1 spark plug. Quote Link to comment
Doctor510 Posted May 24, 2016 Report Share Posted May 24, 2016 It's an L20B, its odd that the U67 # is on the block. As far as I know the pan is correct with the block. I'm at Napa to see what they show in images of there pan gaskets. Yes, I like Great Stuff gasket goo! I asked for a 78 L20 gasket set. 78 L20B would have eliminated the chances of getting the wrong gasket, remember he/she is a parts person not a mechanic. Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 78 L20B would have eliminated the chances of getting the wrong gasket, remember he/she is a parts person not a Datsun enthusiast. Quote Link to comment
racerx Posted May 24, 2016 Report Share Posted May 24, 2016 Or go on Autozone website and cross reference gasket to see if it fits L16 - L20 ,which I think it would but just make sure. Quote Link to comment
Speedracer906 Posted May 24, 2016 Author Report Share Posted May 24, 2016 Are you sure it doesn't say U67 on the cylinder head; near the #1 spark plug. You can see why I say U67, My bad. [/url]">http://http://s733.photobucket.com/user/speedracer906/media/IMG_6036.jpg.html'> Quote Link to comment
Speedracer906 Posted May 24, 2016 Author Report Share Posted May 24, 2016 At this point I think I got it, Thanks! Quote Link to comment
datzenmike Posted May 26, 2016 Report Share Posted May 26, 2016 '78 and up blocks might say W58. L16/18/L20B/Z20 and Z22 all take the same oil pan gasket. They just gave you the wrong one is all. Quote Link to comment
