Arkrider410 Posted May 19, 2016 Report Share Posted May 19, 2016 I'm getting a ka24de and don't need the l16 Quote Link to comment
Dolomite Posted May 19, 2016 Report Share Posted May 19, 2016 Not much. The auto trans is worth literally nothing. Quote Link to comment
Lockleaf Posted May 19, 2016 Report Share Posted May 19, 2016 Oil pan, valve cover, engine mount brackets are worth more than the rest of the engine. If it's a good running setup, you might get 150 for everything from a guy who just wants to be up and running. 1 Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 So the parts are worth more than the whole thing 1 Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 so the trans is worth the price of aluminium scrap 1 Quote Link to comment
datzenmike Posted May 20, 2016 Report Share Posted May 20, 2016 I don't know why anyone would put an A87 on an L16. If closed chamber, the compression drops to 8.21 from 8.5. If open chamber it drops all the way to 7.72!!!! Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 I didn't do it Quote Link to comment
datzenmike Posted May 20, 2016 Report Share Posted May 20, 2016 I know. POs are a strange bunch. 1 Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 I think it's stock Quote Link to comment
datzenmike Posted May 20, 2016 Report Share Posted May 20, 2016 No. The L16 only came with a 210, number head. The A87 was an open 45cc combustion chamber, (for use will larger displacement L18) some were closed 41cc from import engines. The 210 head is 38cc. and gives the 8.5 compression. Possibly it was shaved down to raise the compression back up. The bottom of the A87 may be shaved off. Quote Link to comment
racerx Posted May 20, 2016 Report Share Posted May 20, 2016 Are you sure you have an L16 block with an L18 head. Maybe it's an L18 lower and upper. Show pics. 1 Quote Link to comment
Stoffregen Motorsports Posted May 20, 2016 Report Share Posted May 20, 2016 Yeah, if it's an L18, the block alone could be worth some serious bucks. Vintage racers use them as they are the only "legal" engine displacement upgrade to a period correct B-sedan or 2.5 Trans Am racer. Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 Numbers on the block are l16 numbers on head are a87 Quote Link to comment
banzai510(hainz) Posted May 20, 2016 Report Share Posted May 20, 2016 On east coastmay be worth something. Not much here in Northwest. I give them away Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 http://community.ratsun.net/topic/30148-what-kinda-cylinder-head-is-an-a87/in this thread someone states that the a87 head was put on the l16 Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 http://s947.photobucket.com/user/arkrider410/media/Mobile%20Uploads/tmp_28988-IMAG0060-1929243252.jpg.html?sort=3&o=0Here's a pic of the number on the block Quote Link to comment
Arkrider410 Posted May 20, 2016 Author Report Share Posted May 20, 2016 http://s947.photobucket.com/user/arkrider410/media/Mobile%20Uploads/tmp_28988-IMAG0058-2136151727.jpg.html?sort=3&o=2Here's the head Quote Link to comment
fisch Posted May 20, 2016 Report Share Posted May 20, 2016 Unless you find a purist who wants to take the Datsun back to stock, they aren't worth much. I just got one in new england for essentially free (with a bunch of other stuff), because it had Z flattops, mild cam, aluminum flywheel, and I think less than 10 mi on it, lol. THe head is worth something certainly! California Datsun tries to get $600 for that head all prettied up. Quote Link to comment
Draker Posted May 20, 2016 Report Share Posted May 20, 2016 I think the money is in that head.. assuming it's a closed chamber head. It's been shaved though. 1 Quote Link to comment
datzenmike Posted May 20, 2016 Report Share Posted May 20, 2016 This head has been shaved to raise the compression. The bottom of the A87 is chopped off. I don't know why anyone would put an A87 on an L16. If closed chamber, the compression drops to 8.21 from 8.5. If open chamber it drops all the way to 7.72!!!! No way Nissan would have run that low a compression. So they must have shaved them or they didn't run them. No. The L16 only came with a 210, number head. The A87 was an open 45cc combustion chamber, (for use will larger displacement L18) some were closed 41cc from import engines. The 210 head is 38cc. and gives the 8.5 compression. Possibly it was shaved down to raise the compression back up. The bottom of the A87 may be shaved off. Unshaved... Quote Link to comment
Stoffregen Motorsports Posted May 21, 2016 Report Share Posted May 21, 2016 To clarify the casting number thing, just because the numbers don't show in full doesn't mean the had has been cut. Casting shift happens during the setup process and a lot of heads came out with the bottom of the numbers cut off. Quote Link to comment
racerx Posted May 21, 2016 Report Share Posted May 21, 2016 He needs to measure it Quote Link to comment
datzenmike Posted May 21, 2016 Report Share Posted May 21, 2016 Anything's possible but the only ones I have seen here that were cut off were milled down. A87 combustion chambers are open... 45.3cc or closed.... 41. As far as I'm concerned they were not used on an L16 because of the much lower compression ratios produced. If as Doug says they were used on the '73 L16 then it's assumed that they either had very poor compression or were milled down to raise them back up. An open chamber A87 would need 1.2mm or about 0.050" milled to remove about 7cc of chamber volume. This is all just a thought experiment. If you want to know what head you have, open or closed, take it off. If you want to know the combustion chamber volume.... http://community.ratsun.net/topic/358-how-to-cc-your-cylinder-head-for-free/ Quote Link to comment
datsunaholic Posted May 21, 2016 Report Share Posted May 21, 2016 No. The L16 only came with a 210, number head. The A87 was an open 45cc combustion chamber, (for use will larger displacement L18) some were closed 41cc from import engines. The 210 head is 38cc. and gives the 8.5 compression. Possibly it was shaved down to raise the compression back up. The bottom of the A87 may be shaved off. No, 1973 L16s came with open chamber A87s. Every '73 L16 I've seen that matched the engine number on the dataplate had an A87 head, both in 510s and 620 pickups like my Mom's '73 620, which she's had since new and the engine and head are original. Whether the pistons have less dish than the 210-casting head L16s I don't know. But import L16s came with W53 heads as well. The L16 was manufactured into the early '80s for replacement engines as well as non-American markets, but the 210 head was pretty much done after the 1972 model year. There are a lot of "specs" posted on what heads have what chambers, valves, and ports but reality is they vary widely even from casting number to casting number. There are open and closed versions of almost all heads- if you look closely, they were ALL cast as a closed chamber head and then some were machined open at the factory to lower the compression so that American crappy sub-90 octane gas could be used for emissions purposes (higher compression caused higher NOx emissions due to higher combustion temperatures). But for proof that the "specs" given for Nissan heads isn't always right, I have a 219 head sitting in my garage with 1.38" intake ports. Every manual, list, etc says that 219 heads have 1.50" intake ports. It was a stock head off a Central American L14 engine. 1 Quote Link to comment
Stoffregen Motorsports Posted May 21, 2016 Report Share Posted May 21, 2016 That's a solid point. Going off North American specs does not take into account the thousands of imported engines. As far as I'm concerned, the only way to know what combustion chamber, valve size, port size or thickness a cylinder head has is to visually inspect it and take measurements. Quote Link to comment
