kingfuzzz Posted May 17, 2016 Author Report Share Posted May 17, 2016 I totally get it. And I have a while before I get to build mine. I always spend way too much time researching whatever I do though, which is why I am here already asking questions. Thanks for the info on the Icehouse too 1 Quote Link to comment
flatcat19 Posted May 17, 2016 Report Share Posted May 17, 2016 I get it dude. No hard feelings. I will be buying a KC for sure considering my size, it just makes sense. As for motors, I am completely happy with an l16 to start with. I would rather have the it running and have the rest of the truck where i want it before i blow my load on a swap then not be able to do anything else how I want. I will most likely go the KA route when the time comes, and I have Redeye's page saved for easy access. Also, you mentioned Icehouse's setup and I am wondering if you know how that would compare to a MegaSquirt setup? Icehouses setup complements the ECU system by creating a single interface to power all the ECU operations, it does not replace it. Think of the ECM as providing input and feedback to the motor only. Well, you need to be able to provide power to the motor. The Can-Am box allows for easiest wiring add-on to supply power to circuits the ECM will not do. Fuel pump, ignition, etc. Quote Link to comment
kingfuzzz Posted May 17, 2016 Author Report Share Posted May 17, 2016 Got ya. I found the thread that talks about them. Illhave to see if they still make them and how to order when the time comes. Quote Link to comment
Lockleaf Posted May 17, 2016 Report Share Posted May 17, 2016 Yes, still made. Send a private message to Icehouse to order one or get current pricing on them. Quote Link to comment
kingfuzzz Posted May 18, 2016 Author Report Share Posted May 18, 2016 Yes, still made. Send a private message to Icehouse to order one or get current pricing on them. Nice thanks! Quote Link to comment
datzenmike Posted May 18, 2016 Report Share Posted May 18, 2016 Well.... at least he didn't say LS1 swap. 2 Quote Link to comment
DatsuNissanLove Posted May 18, 2016 Report Share Posted May 18, 2016 Its alot of work but it can be done.. its been done plenty of times before... if you do an sr20det you will have to do some custome fabrication on the intercool system a few other things other den the intercool system.... i believe if you go sr20de it would be a way easier fit.. 1 Quote Link to comment
Lockleaf Posted May 18, 2016 Report Share Posted May 18, 2016 What makes a non turbo SR worth the money over a KA swap? They cost more and you get less, plus parts cost a premium. Quote Link to comment
kingfuzzz Posted May 18, 2016 Author Report Share Posted May 18, 2016 I think I want an SR20DET but mainly because a Silvia is one of my dream import cars. I know its expensive and a lot of work and I dont actually plan on doing it though. I will most likely go the KA route. I do not want to make it hard to drive and pushing 350+ or whatever horsepower. I just want a good amount that will make it fun to cruise but when still be able to get out of its own way. Quote Link to comment
]2eDeYe Posted May 18, 2016 Report Share Posted May 18, 2016 .. ive been doing alot of research on the non turbo sr's n i might just go that route.. but i do know how to fabricate n weld so idk.. still debating... If I could get some stock SR brackets I'd be able to develop some for the 620. Still haven't been able to obtain a set though. 2 Quote Link to comment
sr20ve620 Posted May 18, 2016 Report Share Posted May 18, 2016 SR20 isn't a tough swap by no means. The KA isn't either. The info is all over. L series motors are great though. I'm picking up another 78 KC today for stupid cheap. It will be KA swapped in the next few weeks. If your going for power, it costs. and will probably never hookup.(my race truck for example). Good Luck with yours 1 Quote Link to comment
2wheel-lee Posted May 18, 2016 Report Share Posted May 18, 2016 If I could get some stock SR brackets I'd be able to develop some for the 620. Still haven't been able to obtain a set though. Yeah, hurry up with that already! :thumbup: I should be starting on my SR620 swap within the next couple months. It would be easier than having to make my own or having to buy the ones from CXRacing.com Quote Link to comment
kingfuzzz Posted May 18, 2016 Author Report Share Posted May 18, 2016 SR20 isn't a tough swap by no means. The KA isn't either. The info is all over. L series motors are great though. I'm picking up another 78 KC today for stupid cheap. It will be KA swapped in the next few weeks. If your going for power, it costs. and will probably never hookup.(my race truck for example). Good Luck with yours I cat say I am going for power. I want reliable first. If there is some power for a little fun than ill take it. 1 Quote Link to comment
