datzenmike Posted May 19, 2016 Report Share Posted May 19, 2016 Never fix what ain't broken. Is there something that you're not telling us? Why would you replace the gasket???? Is it leaking coolant??? If no, LEAVE IT ALONE. and move on.... 2 Quote Link to comment
racerx Posted May 19, 2016 Report Share Posted May 19, 2016 Maybe he is talking bout headgasket not waterpump gasket 1 Quote Link to comment
sanyantho Posted May 19, 2016 Author Report Share Posted May 19, 2016 Is there something that you're not telling us? Why would you replace the gasket???? Is it leaking coolant??? If no, LEAVE IT ALONE. and move on When I removed the water pump, the gasket came loose and ripped. So I have to replace it. I removed the water pump because I am replacing the timing chain, since I am changing the head. Everything already opened. 1 Quote Link to comment
sanyantho Posted May 19, 2016 Author Report Share Posted May 19, 2016 Weak mouse trap springs can be fixed. Just squeeze the "bar" and the "legs" closer together. Thanks, could have use this info about a 2 weeks ago. Quote Link to comment
racerx Posted May 19, 2016 Report Share Posted May 19, 2016 That's okay. Look at it as a learning experience. While you already have the head off check the cylinder walls? you may want to consider a total rebuilt, depends on how many miles your car. 1 Quote Link to comment
banzai510(hainz) Posted May 19, 2016 Report Share Posted May 19, 2016 aIf you knew your were going to pull the pump you should have had a spare gasket ready. Thats why one should be 2/3 felpro front cover kets to be readdy all the time. You dont need to take the water pump off when doing a timming chain but once you go that far and motor is old maybe put a new pump on. Quote Link to comment
sanyantho Posted May 19, 2016 Author Report Share Posted May 19, 2016 That's okay. Look at it as a learning experience. While you already have the head off check the cylinder walls? you may want to consider a total rebuilt, depends on how many miles your car. Cylinder walls looks good. I do not want to pull the whole motor out for a rebuild. BTW I wish I had a tree to work under, I working on my drive way and its hot as hell. lol Quote Link to comment
sanyantho Posted May 19, 2016 Author Report Share Posted May 19, 2016 aIf you knew your were going to pull the pump you should have had a spare gasket ready. Thats why one should be 2/3 felpro front cover kets to be readdy all the time. You dont need to take the water pump off when doing a timming chain but once you go that far and motor is old maybe put a new pump on. I was not thinking ahead. I had to remove the radiator and fan guard to replace the fan belt anyways. So my as well replace timing chain and water pump since the motor is old. Quote Link to comment
racerx Posted May 19, 2016 Report Share Posted May 19, 2016 that's right you live by Roseville? Gets hot over there. Try to find a tarp or something, Quote Link to comment
sanyantho Posted May 20, 2016 Author Report Share Posted May 20, 2016 Hi All, I brought a Japanese timing chain kit from Ebay and found that it is too long. Am I suppose to shorten it to size? 1 Quote Link to comment
banzai510(hainz) Posted May 20, 2016 Report Share Posted May 20, 2016 L16/18 L20 is longer depending on year of 620 some had L16s and L18 then L20s. Hopefully you went by motor size Quote Link to comment
sanyantho Posted May 20, 2016 Author Report Share Posted May 20, 2016 L16/18 L20 is longer The seller said that it would fit a L18, does that mean I have to shorten it myself? Quote Link to comment
racerx Posted May 20, 2016 Report Share Posted May 20, 2016 I would return it if it does not fit. Quote Link to comment
Doctor510 Posted May 20, 2016 Report Share Posted May 20, 2016 Hi All, I brought a Japanese timing chain kit from Ebay and found that it is too long. Am I suppose to shorten it to size? You got the chain for an L20B, get one for any Z car 240,260,280 they will fit an L18, CHAIN only, tensioner body is different in the 6 cyl. Quote Link to comment
banzai510(hainz) Posted May 22, 2016 Report Share Posted May 22, 2016 Buy a L18 chain. ckeck the part numbers X ref them. a Jap kit from Tsubaki is best Rcerx I think got one from a part warehouse somewhere Quote Link to comment
racerx Posted May 23, 2016 Report Share Posted May 23, 2016 Got mine from winchester auto, san jose. Ca. Check ur local autostore for tsubaki timing chain. Quote Link to comment
sanyantho Posted June 1, 2016 Author Report Share Posted June 1, 2016 Hi Ratsuns, So I replaced the head and timing chain for my 620. She starts but runs rough. I was unable to see the timing mark on the pulley with a timing gun. She is blowing a lot off white smoke out the exhaust. When I turn her off, the engine keeps on running for 3 minutes before shutting off. Can someone please help? I am going crazy here! lol Quote Link to comment
racerx Posted June 1, 2016 Report Share Posted June 1, 2016 Check ur spark plugs if super clean then coolant and oil is mixed. You can also do a compression check, if low then somtin is not right. Also check ur dipstick if it looks like malt or choc. Milk headgasket issue. What is ur idle, should be like 800, if idle too high that can cause your engine not to shut off. Main thing is u did not blow a headgasket. Did u torque in sequence? Quote Link to comment
sanyantho Posted June 1, 2016 Author Report Share Posted June 1, 2016 Check ur spark plugs if super clean then coolant and oil is mixed. You can also do a compression check, if low then somtin is not right. Also check ur dipstick if it looks like malt or choc. Milk headgasket issue. What is ur idle, should be like 800, if idle too high that can cause your engine not to shut off. Main thing is u did not blow a headgasket. Did u torque in sequence? I didnt torque in sequence, I just torque head bolts from the inside to out. Idle is diffidently high, I dont have the tech meter to tell exactly. I will check on the rest tomorrow. Thanks RacerX Quote Link to comment
racerx Posted June 1, 2016 Report Share Posted June 1, 2016 In the meantime, check ur spark plugs and dipstick. Quote Link to comment
banzai510(hainz) Posted June 1, 2016 Report Share Posted June 1, 2016 torq inside out is fine If unable to see timming marks with the gun then your not even close to have the timming right. Might be hard to tell if not running good You put motor back to TDC recheack the rorotro and see if on #1 plug wire. Better be real close. or remove the dist and recheck the dist spindle and see if close to 11/28 position. if white soem sometimes the intake bolts are loose and its sucking water in from the intake. If you have water passage holes in the head 1 Quote Link to comment
racerx Posted June 1, 2016 Report Share Posted June 1, 2016 disconnect the coil spark plug wire first. Take the dist. cap off and get an adjustable wrench and turn the crankshaft bolt and watch the rotor. While doing this watch for timing marks. When it's at TDC, your rotor should be pointing towards the radiator and now line up the dist. and number one spark plug wire and should be very closed to TDC. Your timing mark should also line to TDC. Also take the valve cover off and the 1st 2 cam lobes should be at 10 and 2 ocklock position. Quote Link to comment
banzai510(hainz) Posted June 1, 2016 Report Share Posted June 1, 2016 racerx Not all distributors will point at the radiator side when at #1. long as the dist/oil spindal is 11/28 and then dist is mounted and the rotor locks down that will be assigned the #1 position.(its up to you to get the dist plate/adjusted in the middle).then from here you get it adusted while running. Quote Link to comment
sanyantho Posted June 1, 2016 Author Report Share Posted June 1, 2016 disconnect the coil spark plug wire first. Take the dist. cap off and get an adjustable wrench and turn the crankshaft bolt and watch the rotor. While doing this watch for timing marks. When it's at TDC, your rotor should be pointing towards the radiator and now line up the dist. and number one spark plug wire and should be very closed to TDC. Your timing mark should also line to TDC. Also take the valve cover off and the 1st 2 cam lobes should be at 10 and 2 ocklock position. I did this, my timing mark is within 5 degree TDC. 1st 2 lobes are at 10 and 2 o clock or very close to it. My dizzy shaft tang is at 11:28. When I start the truck and warm up the engine, I cant see the timing mark with the gun. Also do you guys know why that I am idling so high? Thanks Quote Link to comment
sanyantho Posted June 1, 2016 Author Report Share Posted June 1, 2016 torq inside out is fine If unable to see timming marks with the gun then your not even close to have the timming right. Might be hard to tell if not running good You put motor back to TDC recheack the rorotro and see if on #1 plug wire. Better be real close. or remove the dist and recheck the dist spindle and see if close to 11/28 position. if white soem sometimes the intake bolts are loose and its sucking water in from the intake. If you have water passage holes in the head intake manifold bolts? Quote Link to comment
