MapleNuts Posted September 23, 2016 Author Report Share Posted September 23, 2016 thanks mike that's great to know. yeah i was being a noob idiot racerx it was a screw in type, hot, and throttle wide open. also did a leakdown and it was about 15% loss on all cyl Quote Link to comment
datzenmike Posted September 24, 2016 Report Share Posted September 24, 2016 Mike, in his case, will a leak down test be better? Well he said the compression was even across all cylinders so a leak down won't point to anything much. If one were lower it might point to one of the valves leaking, a gasket or the rings. 15% isn't bad. 25% to 30% is getting pretty bad. Quote Link to comment
