GERMS Posted May 9, 2016 Report Share Posted May 9, 2016 Hello, after a long time of not working on my 620, I've gained enough funds to go at it finally. A 1995 240SX KA24DE will be going in with a 720 5 Speed transmission. I don't have a flywheel nor clutch. I'm aware that you can't go wrong with exedy; however, before I buy, if you all would be kind enough to confirm that this is what I need....also, I read that the D21 truck flywheel and clutch are bigger; does anyone recommend I go that route instead? This 620 will be for commuting/cruising/hauling, no racing, although I might look into adding a turbo in the far future. http://www.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-HD-FLYWHEEL-fits-1991-1998-NISSAN-240SX-2-4L-DOHC-KA24DE-/400782950816?fits=Year%3A1995%7CModel%3A240SX&hash=item5d508681a0:g:Y1QAAOSwDk5ULcoH&vxp=mtr Thank you! Quote Link to comment
Lockleaf Posted May 9, 2016 Report Share Posted May 9, 2016 Yeah d21 is a 240mm clutch surface. S chassis is 225mm. Google "white bunny clutch" Flywheel itself is actually the same diameter 1 Quote Link to comment
flatcat19 Posted May 9, 2016 Report Share Posted May 9, 2016 +1 for white bunny. D21 flywheel. Maybe something lightened. And I think a 300zx clutch for more holding power. Quote Link to comment
GERMS Posted May 9, 2016 Author Report Share Posted May 9, 2016 I think since I'll be driving it stock for a long while I can't justify spending double on that. With that in mind, should I then get this D21 Exedy kit? http://m.ebay.com/itm/EXEDY-CLUTCH-PRO-KIT-HD-FLYWHEEL-fits-NISSAN-PATHFINDER-UFCCKUP-720-D21-2-0L-2-4-/182110463110?nav=SEARCH There's also two other kits...one is stage 1 and stage 2 for only a couple more dollars. Which one should I go for? Thanks Quote Link to comment
Lockleaf Posted May 9, 2016 Report Share Posted May 9, 2016 FWIW, I hate driving stock cars with performance clutches. They take more rpm and more finesse to engage with chattering the hell out the car. When there is additional power on hand to match them, they work great, but without it, I'm of the opinion they suck. D21 is already an upgrade from S chassis. I would say just go with that. 1 Quote Link to comment
]2eDeYe Posted May 9, 2016 Report Share Posted May 9, 2016 Be sure that your pressure plate/flywheel uses 9 bolts instead of 6 when going to the larger clutch. Here is what I found when I ran the 6 bolt setup I think I figured out what happened with the clutch as well. The wear on the flywheel and pressure plate is weird and patchy. I noticed the flywheel in the truck has only 6 tapped holes for the pressure plate. The pressure plate for the stock 240mm clutch needs 9 bolts. I think there was just not enough clamping force for the pressure plate. The new flywheel has 9 tapped holes so we will see once I get the driveshafts back in and take it for a drive. You should be able to make out the patchy wear in this shot. Quote Link to comment
GERMS Posted May 9, 2016 Author Report Share Posted May 9, 2016 Hey RedEye thanks for the heads up! Hey were you able to use the same bolts from your L20B transmission bell housing with the KA/720 5 Speed bell housing? Lengths the same? Quote Link to comment
]2eDeYe Posted May 9, 2016 Report Share Posted May 9, 2016 Yes those are all the same. The starter may need to be drilled out to allow bolting to the bell housing if you are using a 720 transmission. Check your configuration before installing the motor or trans in the truck. Quote Link to comment
GERMS Posted May 9, 2016 Author Report Share Posted May 9, 2016 I was aware of the starter issue from reading your awesome build thread. I will probably just buy a 720 starter as my 620 one was giving me issues anyway. 1 Quote Link to comment
