WAGON kade fuel return
So, I've done a kade swap into my '72 WAGON.  I've got it running using the CanAm box and all seems to work properly but I think I have a fuel issue.  I attempted to run the return through the stock return setup on the wagon which didn't turn out so well.  Leaking fuel everywhere in the rear of the car even with all new hoses....I assume because this system was designed mainly for vapor in a carb'd setup....
For those that have done this swap in a Wagon using a stock fuel tank, how did you set up your return and how did it work out?  I'm guessing I'll need to remove the tank and have a return welded in?
I did do a search on this and didn't find anything Goon specific...... Any help appreciated!!!
  • Replies 4
