Mopar-Datsun Posted July 6, 2016 Author Report Share Posted July 6, 2016 Put some battery cables together from some car audio stuff. 1 Quote Link to comment
Mopar-Datsun Posted July 6, 2016 Author Report Share Posted July 6, 2016 Made a shift knob in 5 minutes. Quote Link to comment
datzenmike Posted July 6, 2016 Report Share Posted July 6, 2016 Finally someone with the sense to get the correct rim off set so they actually fit. Positive battery post needs a cover. The stock engine would have been an L20B, no? Early L16 fully finned valve cover too. Quote Link to comment
Mopar-Datsun Posted July 6, 2016 Author Report Share Posted July 6, 2016 Finally someone with the sense to get the correct rim off set so they actually fit. Positive battery post needs a cover. The stock engine would have been an L20B, no? Early L16 fully finned valve cover too. And they still slightly rub under the right conditions ;) Thanks for the tip on the cover for the terminal. Yes original was a numbers matching L20B. It's sitting on a stand waiting for a rebuild. Quote Link to comment
INDY510 Posted July 6, 2016 Report Share Posted July 6, 2016 It's also nice to have the positive side of the battery towards the motor ... so if it moves it doesn't hit the inner fender. You could maybe rotate it 180 degrees so the terminals aren't at the front, which isn't the stock layout anyway. 2 Quote Link to comment
Mopar-Datsun Posted July 6, 2016 Author Report Share Posted July 6, 2016 It's also nice to have the positive side of the battery towards the motor ... so if it moves it doesn't hit the inner fender. You could maybe rotate it 180 degrees so the terminals aren't at the front, which isn't the stock layout anyway. Thanks...I'll flip it this weekend. Quote Link to comment
datzenmike Posted July 7, 2016 Report Share Posted July 7, 2016 Nothing like welding a wrench to the rad support or worse blowing a hole in the rad. Glue some rubber on the underside of the hood above the battery also. Not that noticeable and everyone will copy you. Yeah the battery is actually in backwards. Looks good. Quote Link to comment
Mopar-Datsun Posted July 8, 2016 Author Report Share Posted July 8, 2016 I'm getting my exhaust done next week. I'm running an L18 with a mild cam and a weber, soon to be swapped with dual SUs. What size pipe? 2" too big? What muffler? Resonator or no? I want something that sounds cool, not annoying. Any suggestions? Quote Link to comment
Lockleaf Posted July 8, 2016 Report Share Posted July 8, 2016 I don't believe resonators are ever a bad idea. They dont really cost power and shave the horrid sharps out of that exhaust tones 1 Quote Link to comment
banzai510(hainz) Posted July 9, 2016 Report Share Posted July 9, 2016 resonanter and a turbo 2 or 3 chamber that fits in the stock location. might have to order it. but a turbo will be fine and close to 2inch will be fine aluminized pipe so it last forever. 2in is more than enough Quote Link to comment
Mopar-Datsun Posted July 18, 2016 Author Report Share Posted July 18, 2016 Ed Hanson's for a new exhaust. Quote Link to comment
Mopar-Datsun Posted July 18, 2016 Author Report Share Posted July 18, 2016 Old exhaust notice the scrapes. Quote Link to comment
Mopar-Datsun Posted July 19, 2016 Author Report Share Posted July 19, 2016 New exhaust 1 Quote Link to comment
Mopar-Datsun Posted July 19, 2016 Author Report Share Posted July 19, 2016 http://vid150.photobucket.com/albums/s84/photosforweb13/IMG_0208.mp4 Quote Link to comment
MapleNuts Posted September 4, 2016 Report Share Posted September 4, 2016 Pulled up the carpet and was stoked to find the floorpans like this. California lucky! Yeah you did! my washington car had the gas pedal fall through the floor when i was driving! this thing is pretty clean! Quote Link to comment
REDnGOLD Posted January 18, 2017 Report Share Posted January 18, 2017 What seat rails or brackets did u use for the Z4 seats? Or did u end up bolting it to the floor? Quote Link to comment
Mopar-Datsun Posted February 6, 2017 Author Report Share Posted February 6, 2017 I had a friend weld in some custom brackets. Quote Link to comment
Redrumls Posted February 7, 2017 Report Share Posted February 7, 2017 I went to look at one like yours to purchase but was missing a lot of parts. Still for sale. The 610's are a nice looking car. Greg 1 Quote Link to comment
ArchetypeDatsun Posted February 9, 2017 Report Share Posted February 9, 2017 Man if that was close to me I would have loved to pick that up i can only imagine the before and after. Quote Link to comment
