Sierra Posted April 29, 2016 Report Share Posted April 29, 2016 Has anyone done a Carb to EFI on a A Series engine? I am contemplating on doing this. I got a system coming from Australia. Any input and/or positive feedback would be greatly appreciated. Quote Link to comment
Draker Posted April 29, 2016 Report Share Posted April 29, 2016 A series had a rare efi manifold. If you have the mani and other electrical bits, I wouldn't think it'd be that hard. very similar to the L18 efi setups I'm sure. Quote Link to comment
bilzbobaggins Posted April 29, 2016 Report Share Posted April 29, 2016 Pics of your setup to be delivered? Quote Link to comment
Tolkmod Posted April 29, 2016 Report Share Posted April 29, 2016 Pics of your setup to be delivered? I wouldn't mind seeing this, and or links to where you bought it.... Quote Link to comment
Sierra Posted April 29, 2016 Author Report Share Posted April 29, 2016 It pop-up on ebay. I was the only one that placed a bid so I won the auction. Here are some of the pictures that the seller post on ebay. Quote Link to comment
Draker Posted April 29, 2016 Report Share Posted April 29, 2016 You'll need an injectors, ecu, harness, and maf Did it come with it? I mean.... this is an important part to have for sure. But you'll need an ecu and maf for an engine approximately 1.2 liters. Quote Link to comment
jrock4224 Posted April 29, 2016 Report Share Posted April 29, 2016 It pop-up on ebay. I was the only one that placed a bid so I won the auction. Here are some of the pictures that the seller post on ebay. i watched that i may even have bid on it ... ssorry if i ran you up .. 1 Quote Link to comment
Sierra Posted April 29, 2016 Author Report Share Posted April 29, 2016 @ Draker, It comes with the intake and exhaust manifold. I know it needs new injectors and that the fuel rail was repaired. What do you mean by "maf"? I am also under the impression that, I can get a ecu fairly easy. Am I correct? @ jrock4224 I think the one you mention was a different one. I saw that one too but the price on that one went way out of my budget. here is a picture of the exhaust Quote Link to comment
Lockleaf Posted April 29, 2016 Report Share Posted April 29, 2016 MAF = mass air flow sensor. Tells ecu how much air is going in to the motor, so it can inject the fuel correctly. It is very likely you could use L or Z series parts to make up the missing pieces. The A series fuel injection was used on some later fork lifts as well, so you might be able to get some parts that way Quote Link to comment
datzenmike Posted April 29, 2016 Report Share Posted April 29, 2016 This is an old technology very rudimentary EFI from Datsun. Probably a Bosch batch fire set up. However you can use this as the heart of a much newer updated EFI. You need injectors, MAF, high pressure fuel pump and regulator, O2 sensor, air regulator valve, A.I.S. unit. (I see a throttle valve switch) Might be better to get a Maga Squirt and be done with it. Very programmable with a lap top. 1 Quote Link to comment
oakrun Posted April 29, 2016 Report Share Posted April 29, 2016 Has anyone done a Carb to EFI on a A Series engine? I am contemplating on doing this. I got a system coming from Australia. Any input and/or positive feedback would be greatly appreciated. Has anyone done a Carb to EFI on a A Series engine? I am contemplating on doing this. I got a system coming from Australia. Any input and/or positive feedback would be greatly appreciated. I would tell the seller to keep that exhaust manifold. Its nothing special and weighs quite a bit. Shipping heavy stuff from/to oz is expensive. 1 Quote Link to comment
datzenmike Posted April 29, 2016 Report Share Posted April 29, 2016 Has the bung for the O2 sender but most people delete the EGR so that hole could also be used. Quote Link to comment
Sierra Posted April 30, 2016 Author Report Share Posted April 30, 2016 Sounds like I am way over my head with this swap, but I love a challenge. I will continue to gather information. I like the idea of using the "bones" of the EFI system and creating something more up to date. Thanks everyone for the input. Quote Link to comment
tboe0 Posted April 30, 2016 Report Share Posted April 30, 2016 Why cant I find things like that on Ebay?! :frantics: Quote Link to comment
datzenmike Posted April 30, 2016 Report Share Posted April 30, 2016 Sounds like I am way over my head with this swap, but I love a challenge. I will continue to gather information. I like the idea of using the "bones" of the EFI system and creating something more up to date. Thanks everyone for the input. A project for sure but it sure won't look 'home made' with that intake. A stand alone system like MegaSquirt' will allow you to tune and understand how it all works. The stock one is just a mystery. If something goes wrong all you can do is start replacing parts at random. EFI are great starters when cold, good mileage and performance (which is hard to do) hell, it will run upside down even. Quote Link to comment
B210ratsun Posted April 30, 2016 Report Share Posted April 30, 2016 Good suggestion Mike. MegaSquirt would be the way to go for sure! Injectors, call deatschwerks tell them your scenario and they may be able to suggest an injector size. I think one main hurdle would be the fitment of new injectors. Quote Link to comment
Tolkmod Posted May 1, 2016 Report Share Posted May 1, 2016 Seriously cool... even though I'll be swapping out my A13 for a L20b it's still cool... I'm subbed and looking forward to seeing this progress!! And don't forget, LOTS OF PICS MAN!!! Quote Link to comment
jrock4224 Posted May 2, 2016 Report Share Posted May 2, 2016 i will take that ex mani though Quote Link to comment
Sierra Posted May 15, 2016 Author Report Share Posted May 15, 2016 Got my inlet manifold and other goodies today. Exhaust comes later. It looks like the previous owner gave up on the project. it looks like he was trying different wire harness. Here are some shots of the stuff I got. Quote Link to comment
Cosmonaut Posted May 22, 2016 Report Share Posted May 22, 2016 I need to go wipe.....have a butt full of jelly right now 1 Quote Link to comment
jrock4224 Posted May 23, 2016 Report Share Posted May 23, 2016 nice ... excited to se this happen Quote Link to comment
