Mopar-Datsun Posted April 23, 2016 Report Share Posted April 23, 2016 I was going through my pics and can't remember if I ever posted these. This is how I put Miata seats in my 620. I'm not very good at this type of thing, but hopefully this helps someone. 3 Quote Link to comment
2wheel-lee Posted April 24, 2016 Report Share Posted April 24, 2016 I was thinking of putting these in my standard cab, but I'm concerned about space. How thick are those seats at the height just below the rear window? Quote Link to comment
Mopar-Datsun Posted April 25, 2016 Author Report Share Posted April 25, 2016 I sold the truck a couple years ago. The height was good. Pretty close to stock. Maybe just a little taller. Quote Link to comment
distributorguy Posted April 25, 2016 Report Share Posted April 25, 2016 Seat back thickness is WAY too thick. You lose at least 2" of space. At least! You can carve foam out of the seat and make more room, but you never get it all back. Tried that. Removed them, and I'm only 5'10. Quote Link to comment
2wheel-lee Posted April 25, 2016 Report Share Posted April 25, 2016 I'm about 5'11". The stock bench goes up to just under the body protrusion under the rear window. But because the way it sits in there, there's about an inch or so between my back and the protrusion. Any good recommendations on bucket seats that are thin in that area just below the back window? I'd kind of like to have a head rest, of sorts, so my head won't hit the rear glass. I love these. as the seat tucks just under the protrusion: 3 Quote Link to comment
mcordero8 Posted April 25, 2016 Report Share Posted April 25, 2016 I am 6'1" I put BMW Z3's in my standard cab 620. It was not a direct fit, but with some mods its doable. Mine is not a daily driver, but when I do drive it its more comfy then the stock bench. Quote Link to comment
2wheel-lee Posted April 25, 2016 Report Share Posted April 25, 2016 I am 6'1" I put BMW Z3's in my standard cab 620. It was not a direct fit, but with some mods its doable. Mine is not a daily driver, but when I do drive it its more comfy then the stock bench. How thick is the seat at the protrusion just below the back window? Quote Link to comment
mcordero8 Posted April 26, 2016 Report Share Posted April 26, 2016 It's about 3 inches. 1 Quote Link to comment
abbylind Posted April 26, 2016 Report Share Posted April 26, 2016 Ditto on the Z3s. Standard cab Im 6'...Lots better then that bench seat 1 Quote Link to comment
distributorguy Posted April 26, 2016 Report Share Posted April 26, 2016 Another plentiful option would be MGB seats with the headrest removed. Early style use a rubber diaphragm under the seat cushion and sit very low. Quote Link to comment
Scgreen620 Posted October 19, 2016 Report Share Posted October 19, 2016 Has any one tried Isuzu amigo seats? Quote Link to comment
Scgreen620 Posted October 25, 2016 Report Share Posted October 25, 2016 I've seen s10 Seats in standard cab ...don't know how they fit tho Quote Link to comment
Scgreen620 Posted October 25, 2016 Report Share Posted October 25, 2016 Seat back thickness is WAY too thick. You lose at least 2" of space. At least! You can carve foam out of the seat and make more room, but you never get it all back. Tried that. Removed them, and I'm only 5'10. Do you lose the space because of the head rest? Quote Link to comment
Scgreen620 Posted October 25, 2016 Report Share Posted October 25, 2016 I was on the fwy today and I saw a older Miata the seat seems like it's 3 inches thick .... How won't that work? Quote Link to comment
