flatcat19 Posted April 18, 2016 Report Share Posted April 18, 2016 So...this happened last night... So I am needing a fuse box. Planning on buying a more modern one. I'm at work so I'll post links later of the options I'm thinking about. My querry... What else should I be doing while replacing my fuse box? Or...what boxes have others used to upgrade their 521s? Posting a thread for this because I don't want the info to get lost in my thread. Replacing box/updates will happen in my thread. 2 Quote Link to comment
thisismatt Posted April 18, 2016 Report Share Posted April 18, 2016 Blue Sea Systems 1 Quote Link to comment
Rick-rat Posted April 18, 2016 Report Share Posted April 18, 2016 Jack up your radiator cap and drive a 620 under it :thumbup: 1 Quote Link to comment
flatcat19 Posted April 18, 2016 Author Report Share Posted April 18, 2016 Blue Sea Systems That was one of the ones I was looking at. I didn't like that the connections weren't exposed. Do you have one installed? Pics? 1 Quote Link to comment
flatcat19 Posted April 18, 2016 Author Report Share Posted April 18, 2016 Jack up your radiator cap and drive a 620 under it :thumbup: Only if it was yours. 1 Quote Link to comment
KoHeartsGPA Posted April 18, 2016 Report Share Posted April 18, 2016 Yikes!, find the cause...though it looks like fatigue rather than an overload of the system.... 1 Quote Link to comment
flatcat19 Posted April 18, 2016 Author Report Share Posted April 18, 2016 Cause? Because it broke. I know why. It was the big fucking hole I fell in to on my way home last night. Bent my battery tie down rods which tugged on the fuse box ever so slightly. Boom! Ready for the mind fuck...I drove home. Albeit without any lights. 4 Quote Link to comment
banzai510(hainz) Posted April 18, 2016 Report Share Posted April 18, 2016 JB weld the backside 3 Quote Link to comment
HOGIE Posted April 18, 2016 Report Share Posted April 18, 2016 I have the piece you broke if you want it. I have a NOS one I'm going to install and the one that's in the truck now is in good shape 2 Quote Link to comment
DanielC Posted April 18, 2016 Report Share Posted April 18, 2016 A blue sea systems fuse box in a 1970 521. 4 Quote Link to comment
flatcat19 Posted April 18, 2016 Author Report Share Posted April 18, 2016 I have the piece you broke if you want it. I have a NOS one I'm going to install and the one that's in the truck now is in good shapeNope. Thanks though. I'm itching for something a little more modern. New. This is what I'm aiming for. \/ A blue sea systems fuse box in a 1970 521. 1 Quote Link to comment
hobospyder Posted April 18, 2016 Report Share Posted April 18, 2016 didn't you put one of those into the canby truck daniel? 1 Quote Link to comment
flatcat19 Posted April 19, 2016 Author Report Share Posted April 19, 2016 I remember seeing it too. Never focused on it until I needed one...which is now; lulz 1 Quote Link to comment
Elkie Posted April 19, 2016 Report Share Posted April 19, 2016 Heres what I'm using, has two busbars built in on the back. 1 Quote Link to comment
Elkie Posted April 19, 2016 Report Share Posted April 19, 2016 Oh and a cover shot. 1 Quote Link to comment
flatcat19 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Heres what I'm using, has two busbars built in on the back. I've been looking at one of those. But that's a long term idea. When I'm ready to do a full rewire that will be the route I go. Relays and fuses all in one spot. Now now though. 2 Quote Link to comment
flatcat19 Posted April 19, 2016 Author Report Share Posted April 19, 2016 http://www.ceshowroom.com/ProductDetails.asp?ProductCode=CWR42730&click=2&gclid=CjwKEAjwi9K4BRCQzq7d1c6A_XASJABueAO2Rw2OxSCRgHqV0kRuWOCKmbd76CLj3EC9w105XuskVhoCEPPw_wcB Going with this one. 1 Quote Link to comment
DanielC Posted April 19, 2016 Report Share Posted April 19, 2016 A Datsun 521 has either three or four always hot fuses. The Blue Sea fuse box has some jumpers that you can use to make the fuse block work for either application. Quote Link to comment
flatcat19 Posted April 19, 2016 Author Report Share Posted April 19, 2016 A Datsun 521 has either three or four always hot fuses. The Blue Sea fuse box has some jumpers that you can use to make the fuse block work for either application. I'm going to install this exactly as it sits in the truck now. Straight drop and swap. 2 Quote Link to comment
banzai510(hainz) Posted April 19, 2016 Report Share Posted April 19, 2016 Thats a nnice fuse block 1 Quote Link to comment
Elkie Posted April 19, 2016 Report Share Posted April 19, 2016 Yeah I'm redoing the whole engine harness atm, so it makes more sense, the dual bus bar is nice one side is always hot the other will be ign hot. Have another one up front with relays for electric fans headlight and a/c. 1 Quote Link to comment
4perrev Posted April 19, 2016 Report Share Posted April 19, 2016 pulled one out of a Nissan sentra and went to town. Had to fab two bus bars, but if was straight forward and now it's in the cab rather than the engine bay!! No rust or water. 1 Quote Link to comment
flatcat19 Posted April 19, 2016 Author Report Share Posted April 19, 2016 I live in TriCities. No rust or water anyways. 1 Quote Link to comment
