Replaced headgasket on my Z24; lost time\tension
SolidZ24x4
  • Replies 34
If you are on TDC compression stroke on #1 cylinder then...... this is perfect
The rotor under the cap has two contacts for two sets of wires from two coils. The intake rotor should be pointing to about 9 o'clock and the exhaust rotor about 4 o'clock. On the cap above the rotor is Intake 1 at 9 o'clock and Exhaust 1 at 4 o'clock.
Finger on Intake one. Exhaust one is three positions counter clockwise.
Take the valve cover off. Compression stroke on number one will see the cam lobes like this... front one (exhaust) at about 8 o'clock and the intake behind it at about 4 o'clock as viewed from the front. Both valves will be closed.
theres a weird whine after i got it started up, first i thought it was an uneven belt, or the fan, but its pretty loud. I'm thinking the cam is off by a tooth or three.
If theres a problem to be found in this project; ill find it.
