J's 620 Posted March 25, 2016 Report Share Posted March 25, 2016 Smoking voltage regulator and 12.4 volts across battery. Regulator kind of makes a noise in sync with the idle. Quote Link to comment
Draker Posted March 25, 2016 Report Share Posted March 25, 2016 Electric choke heater? Quote Link to comment
Draker Posted March 25, 2016 Report Share Posted March 25, 2016 http://community.ratsun.net/topic/58171-l20b-w-stock-carb-cold-start-issues-electric-choke-problem/ Quote Link to comment
datzenmike Posted March 25, 2016 Report Share Posted March 25, 2016 This problem exists on a 76 620 l20b.I'm getting about a 5amp draw when the key is in the on position. When I connect the meter from neg. cable to the neg post im hearing a click near the carb. I'm about to pull the air cleaner off to get a better look. Sounds like a relay. Any bright ideas before I even look? Thanks. Doesn't sound like a problem. The ignition in the ON position turns lots of stuff on like... The ignition relay The points in the distributor The red CHARGE and OIL dash lights The gas and fuel gauges The idle cut solenoid in the carb I'm surprised it's only 5 amps. 1 Quote Link to comment
J's 620 Posted March 26, 2016 Author Report Share Posted March 26, 2016 I apologize I was in a hurry and didn't explain this very well. The issue is a hot voltage regulator. When the key is on it starts to get hot. Quote Link to comment
J's 620 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Again sorry for the dummy post. I want to add that when the motor runs I only get 12 ish volts across the battery. The voltage regulator gets hot. Under the cover of the regulator there is a wire connected to the coils in there and the insulation burned up a bit. No chg light on while running. New p.o.s. reman napa alternator( I mistakenly replaced the old with the reman) Now, this is my 2nd alternator. The first reman worked for 2 weeks. Then the chg light started coming on. So we're on #2 now. I had it tested when I exchanged it and it put out the 14.4-14.6. Recap: 12.4 volts across the battery while running, voltage regulator getting hot and that wire starts cooking, NO chg light on dash. I have solid ground connections. ? Is this a ground problem? Should I get the alternator tested again? Quote Link to comment
datzenmike Posted March 26, 2016 Report Share Posted March 26, 2016 The '76 uses an external regulator. You or NAPA have probably put an internal regulated alternator in your truck. The '78 and up vehicles use this alternator. Quote Link to comment
kelowg Posted March 26, 2016 Report Share Posted March 26, 2016 Ask part house to pull out the alt book. Look up part and verify reg type. Dont trust theyre comp system. Quote Link to comment
J's 620 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Thanks..... it's the part #14105....I will check it out. Although shrewd you always have a great answer and offer great help. I appreciate it. 1 Quote Link to comment
Lockleaf Posted March 26, 2016 Report Share Posted March 26, 2016 That part number shows to be externally regulated. 1 Quote Link to comment
J's 620 Posted March 26, 2016 Author Report Share Posted March 26, 2016 I found a thread here that talks about the napa voltage regulator being a piece of crap. The part# is correct but is the alternator itself correct?? Should I convert the wiring to the internally regulated version to find out? I found the thread on that one as well. Quote Link to comment
J's 620 Posted March 27, 2016 Author Report Share Posted March 27, 2016 I'm going to clear the air of this whole mess. Napa gave me the wrong alternator. Now I have a reman that get to deal with when it goes out. The end. 1 Quote Link to comment
datzenmike Posted March 27, 2016 Report Share Posted March 27, 2016 Does this mean it's fixed? What about the hot regulator? Quote Link to comment
J's 620 Posted March 28, 2016 Author Report Share Posted March 28, 2016 Both napa and autozone keep giving me an alternator that are different than my original. Does this mean it's fixed? What about the hot regulator? No it is not fixed until I find the right alternator I think. My truck has never had this problem. Quote Link to comment
datzenmike Posted March 28, 2016 Report Share Posted March 28, 2016 Well it might not be exactly the identical same looking. It has to bolt in and presumably be an external regulated one. Quote Link to comment
J's 620 Posted March 29, 2016 Author Report Share Posted March 29, 2016 I had the part store order me an alt for a 78....just out of curiosity, it came today and was the same alternator they offer for my 76. So that's my problem. Quote Link to comment
J's 620 Posted December 4, 2016 Author Report Share Posted December 4, 2016 I did an alternator swap. It will go in a build thread. Quote Link to comment
J's 620 Posted December 6, 2016 Author Report Share Posted December 6, 2016 Topic should be changed to.....wrong alternator. Quote Link to comment
