Scgreen620 Posted March 2, 2016 Report Share Posted March 2, 2016 Any one run electric fans or a fan for their 620? I just want to know what's the best to use 1 12inch or 2 8 inch?What kit have you guys used I see some eBay ones are they any good? I just don't want a fan to break down on me thanks 1 Quote Link to comment
sebpv Posted March 2, 2016 Report Share Posted March 2, 2016 just taking the surface area, 1x12in would gets you more cooling surface. So it wouldnt start as often and might be cheaper than buying two 1 Quote Link to comment
MantisX620 Posted March 2, 2016 Report Share Posted March 2, 2016 I used 1 12 inch and kept the shroud. With that said, I either want to try a dual setup or go back to the clutch fan lol. The electric fan works, but Im not too happy with how it has to work to keep the temp gauge down. Maybe I just need to have the fans kick on at a cooler temperature. 1 Quote Link to comment
sebpv Posted March 2, 2016 Report Share Posted March 2, 2016 2x9in would be the equivalent 1 Quote Link to comment
sebpv Posted March 2, 2016 Report Share Posted March 2, 2016 back to the book; what is the desired temp for the coolant? Maybe that will indicate which way you should proceed. 1 Quote Link to comment
orangie Posted March 2, 2016 Report Share Posted March 2, 2016 Look at the CFM rating. Not all fans are alike just because they are the same size. Here in the hot part of AZ, we need everything we can get. 3 Quote Link to comment
G-Duax Posted March 2, 2016 Report Share Posted March 2, 2016 What I run doesn't apply to a stock radiator, because I use a VW Scirocco radiator. But on it, I use 1-12" puller on the back, and 1-10" pusher on the front, offset from the rear. The rear is on 100% of the time, and the front is controled by the Scirocco temp switch. The power from both comes through an 80 amp relay. Works great in 110 degree days here in S. Texas. And like Orangie says, it's not the size, but the flow numbers that count. My 3 liter Toyota with 12:1 compression, had a twin Flexalite on it rated at a little over 2000 cfm, that worked, but barely. But in the same fan size, a Derale twin setup is rated at 4000 cfm, so I went with that, so I have pleanty safety margin. Derale has a single 12" rated a 2000, so there is a big difference in performance from one make to another. 2 Quote Link to comment
Scgreen620 Posted March 3, 2016 Author Report Share Posted March 3, 2016 Well eBay has 2 fans for 68 bucks it includes the kit to make everything work ... Maybe I install 1 to be a puller and one to be a pusher ? Their at 1700 cfm 1 Quote Link to comment
Scgreen620 Posted March 3, 2016 Author Report Share Posted March 3, 2016 The other thing is should I trust an N/A brand or should I go with a good brand and spend big bucks on it? 1 Quote Link to comment
orangie Posted March 4, 2016 Report Share Posted March 4, 2016 I'd go with used OEM stuff. Usually good quality and a fraction of the price. 1 Quote Link to comment
Scgreen620 Posted March 4, 2016 Author Report Share Posted March 4, 2016 What would be a good fan to use then? 1 Quote Link to comment
Lockleaf Posted March 4, 2016 Report Share Posted March 4, 2016 Focus from the early 2000s. Over the in the 720 section, there is a thread about cheap electric fan conversion, and he builds a pretty nice setup. Focus fans (in addition to other ford electric fans) are known for their high cfm draws 2 Quote Link to comment
FrankRizzo Posted March 5, 2016 Report Share Posted March 5, 2016 I hafta say that SPAL makes the best electric fans by far. I ran them in my Turbo Miata which notoriously run hot and it helped a lot. One word of caution with high CFM fans...they make a LOT of noise. When both fans kicked on people would look like WTF?? Especially irritating in a drive-thru when they keep asking to repeat your order.... http://www.summitracing.com/search/product-line/spal-electric-fans . 1 Quote Link to comment
red13 Posted March 5, 2016 Report Share Posted March 5, 2016 I browsed the junkyard for a random one. I have a 12v drill so i can test it before i buy. 2 Quote Link to comment
J's 620 Posted December 8, 2016 Report Share Posted December 8, 2016 (edited) I used a 10 or 11 inch puller. It has a cfm rating of 1200 or so. Not sure what brand but I did get it from summit. Pulls low amps too. Fit/size, cfm rating, and amp draw are the big factors to consider. Oh and maybe how it mounts. I mounted to the radiator brackets using a custom setup. No shroud. It keeps the temp Guage slightly less than dead center. My cracked mechanical fan ran it at dead center or just above. Like someone posted above....there are a few threads on this. But I will post a pic! Edited September 8, 2020 by J's 620 1 Quote Link to comment
J's 620 Posted December 8, 2016 Report Share Posted December 8, 2016 But I will post a pic! Oops I cant. Because I don't have a computer. Sorry. 1 Quote Link to comment
distributorguy Posted December 8, 2016 Report Share Posted December 8, 2016 I recently bought the Ebay fans, and I can vouch for their total lack of quality or cfm. Spend the money and buy a good SPAL fan. Anything else will give you false numbers including Derale. You can run up to a 16" fan on a Datsun radiator. You just need to build a flat shroud to mount it on. Pullers are more efficient. Around $130 all-in, with a legitimate 1000 cfm when mounted: https://www.amazon.com/Spal-30100400-Straight-Blade-Profile/dp/B003PB44LW/ref=sr_1_1?s=automotive&ie=UTF8&qid=1481223620&sr=1-1&keywords=16%22+spal+fan https://www.amazon.com/gp/offer-listing/B003PB41SI/ref=dp_olp_0?ie=UTF8&condition=all 2 Quote Link to comment
J's 620 Posted December 8, 2016 Report Share Posted December 8, 2016 I say go spal as well. You get what you pay for. 1 Quote Link to comment
Stoffregen Motorsports Posted December 9, 2016 Report Share Posted December 9, 2016 I have yet to find an electric fan that really impressed me. OEM fans from european cars (Volvo, BMW, etc) are very high quality, but they draw high amps, sometimes over 50 amps. SPAL certainly has the goods. The best product they had (past tense) was a fan controller that had circuitry for two fans which could start individually and had soft start and variable speed controls. Plus a timer for after the car was shutoff. They discontinued the product, much to my consternation. Seems like whenever something really good hits the market, some bean counter wipes it off the books. 1 Quote Link to comment
KoHeartsGPA Posted December 9, 2016 Report Share Posted December 9, 2016 Well eBay has 2 fans for 68 bucks it includes the kit to make everything work ... Maybe I install 1 to be a puller and one to be a pusher ? Their at 1700 cfm I run 2, 9" pushers, 2400 cfm i believe? Can't recall...got them from summit racing... 1 Quote Link to comment
Scgreen620 Posted December 9, 2016 Author Report Share Posted December 9, 2016 I run 2, 9" pushers, 2400 cfm i believe? Can't recall...got them from summit racing... how loud are they? Is there a link you can hook me up with 1 Quote Link to comment
Scgreen620 Posted December 9, 2016 Author Report Share Posted December 9, 2016 I still have not bought fans btw still on the road to purchasing them 1 Quote Link to comment
Lockleaf Posted December 9, 2016 Report Share Posted December 9, 2016 I have yet to find an electric fan that really impressed me. OEM fans from european cars (Volvo, BMW, etc) are very high quality, but they draw high amps, sometimes over 50 amps. SPAL certainly has the goods. The best product they had (past tense) was a fan controller that had circuitry for two fans which could start individually and had soft start and variable speed controls. Plus a timer for after the car was shutoff. They discontinued the product, much to my consternation. Seems like whenever something really good hits the market, some bean counter wipes it off the books. Have you ever installed the Ford Taurus or Lincoln Mark VII dual speed single fan? Or the Ford Focus dual speed dual fans? Draws are high like you mentioned, but cfm is also quite high. I've pretty much only seen rave reviews about using them, even from V8 crawler type guys. 1 Quote Link to comment
Stoffregen Motorsports Posted December 9, 2016 Report Share Posted December 9, 2016 I have not. Are they pullers? or pushers? What controls them? Is the circuitry built into the fan assembly or a separate piece? Quote Link to comment
J's 620 Posted December 9, 2016 Report Share Posted December 9, 2016 Electric fan conversion is just one step closer to making your ratsun "less valuable". But hey it does work better than my cracked mechanical fan and does NOT run all the time either! Quote Link to comment
