thisismatt Posted June 15, 2016 Report Share Posted June 15, 2016 Roll up door glass is the same. 1 Quote Link to comment
Lockleaf Posted June 15, 2016 Report Share Posted June 15, 2016 If the glass has even the slightest curve to it, then no they won't interchange. If it's perfectly flat, there is a good chance that they will 1 Quote Link to comment
thisismatt Posted June 15, 2016 Report Share Posted June 15, 2016 They are the same. Same part number. They are flat. 1 Quote Link to comment
Datsunthug Posted June 15, 2016 Author Report Share Posted June 15, 2016 Cool. Think I'll pick it up! Thanks 1 Quote Link to comment
flatcat19 Posted June 15, 2016 Report Share Posted June 15, 2016 Dibs I it has a lock knob and door pull and you don't need them. 1 Quote Link to comment
Datsunthug Posted June 15, 2016 Author Report Share Posted June 15, 2016 They want $150 1 Quote Link to comment
Datsunthug Posted June 15, 2016 Author Report Share Posted June 15, 2016 Dunno if $150 is too much. Hard to just find the parts it seems. 1 Quote Link to comment
thisismatt Posted June 15, 2016 Report Share Posted June 15, 2016 If don't really need it, offer him $75 and walk 1 Quote Link to comment
DanielC Posted June 16, 2016 Report Share Posted June 16, 2016 The right and left door glass is different. The window regulator has a roller that rides in a track on the bottom of the sliding glass, and the curved part of the door glass that goes to the front has to stay to the front. There is a very slim chance you might be able to remove the roller track and turn it around, to make a right door glass work on the left, but I would be reluctant to try it with a good window glass. 1 Quote Link to comment
thisismatt Posted June 16, 2016 Report Share Posted June 16, 2016 The roller track comes off. Nissan only has one part number for left and right roll up glass, specifying 2 of the same per truck 1 Quote Link to comment
4perrev Posted June 16, 2016 Report Share Posted June 16, 2016 Why not just buy the glass and not go through the whole door thing? Changing the glass isn't real hard, but does take a bit of time to do right. Heck, if I could do it without instructions, you can too!! 1 Quote Link to comment
hobospyder Posted June 16, 2016 Report Share Posted June 16, 2016 He wants the door to replace the one that has rust bro. Window for the opposite door. Aiming at the package deal from how I understood it 2 Quote Link to comment
Datsunthug Posted June 16, 2016 Author Report Share Posted June 16, 2016 The door has 6 holes from a few different mirrors over the years. Think I'm going to pass on it for now. Weimar auto wrecking, Ca. If someone wants to swoop it Quote Link to comment
Datsunthug Posted June 18, 2016 Author Report Share Posted June 18, 2016 Sometimes I park in handicap spaces to watch handicap people make handicap faces. Cause I'm an asshole Quote Link to comment
banzai510(hainz) Posted June 18, 2016 Report Share Posted June 18, 2016 dude that truck is cool Maybe lower it looks like mine 1 Quote Link to comment
4perrev Posted June 18, 2016 Report Share Posted June 18, 2016 He wants the door to replace the one that has rust bro. Window for the opposite door. Aiming at the package deal from how I understood it Oh, I see now. Sorry for the momentary lapse into stupidity! Oooooops. Go forth and buy doors my lad!! Quote Link to comment
Datsunthug Posted June 18, 2016 Author Report Share Posted June 18, 2016 Had a blast driving into town today! Still have to fix shit but couldn't resist driving around. Quote Link to comment
Datsunthug Posted June 18, 2016 Author Report Share Posted June 18, 2016 This is why I had an exhaust leak!? Bent it back as straight as I could and ran a file over it to check it. Not perfect but best I could do with the tools I have. Apparently my cig lighter drains my battery so i have it on the charger so when I can get it started I can see if my collector is still leaking or not Quote Link to comment
Datsunthug Posted June 18, 2016 Author Report Share Posted June 18, 2016 dude that truck is cool Maybe lower it looks like mine Lowered would look bitchin Quote Link to comment
banzai510(hainz) Posted June 18, 2016 Report Share Posted June 18, 2016 cig lighter draining? something must be spliced from it to power something else. How about unplug it? How you figure this out? get a test light and pull the _ side battery and put the test light on the batter post and the cable you just removed. if the light is ON then the battery is draining. pull the fuse till it stops. If the cig light socket is shorted I guess it would drain the battery but really should pop the fuse. To confirm this see if the lest light on then pull the center wire in back of the cig lighter youtube electrical drain by Scotty kilmer about 40sec into the vid shows how to find a drain 1 Quote Link to comment
Datsunthug Posted June 19, 2016 Author Report Share Posted June 19, 2016 I think j have a short within a wire somewhere. I hate electrical 1 Quote Link to comment
Datsunthug Posted June 21, 2016 Author Report Share Posted June 21, 2016 Kinda figured out the electrical issue?! Battery tie down to keep things tight. Drove it to work tonight it's fun until 50 mph then shit gets exciting like a fair ride put together by a carny 1 Quote Link to comment
banzai510(hainz) Posted June 21, 2016 Report Share Posted June 21, 2016 Well you gonna tell us whats the elelctrical issue? Its Typical Datsun owner tie down is bungy cord but have coil overs on order. its just the way it is 1 Quote Link to comment
Datsunthug Posted June 21, 2016 Author Report Share Posted June 21, 2016 The main problem is I was at idiot for not getting a tiedown on the battery sooner it was sliding around a little , the terminals got loose. The poor little cigarette lighter got blamed for nothing apparently 1 Quote Link to comment
banzai510(hainz) Posted June 21, 2016 Report Share Posted June 21, 2016 me and Icehouse and a running joke that I should bring 10 battery hold down kits to a Datsun meet and I would have to use everyone up. 2 Quote Link to comment
