Datsunthug Posted March 22, 2016 Author Report Share Posted March 22, 2016 Big question of the day?????? I have two different crank pulleys. One from each motor. The one that came off my truck is a single groove pulley with balancing holes drilled into it on the back. The other pulley off the spare motor is a double groove design with no balancing holes or weights. So my question is ? ARE SOME L16s internally balanced while some rely on the crank shaft pulley weights holes. Want to make sure that I use the right parts 1 Quote Link to comment
DanielC Posted March 22, 2016 Report Share Posted March 22, 2016 L-16 engines are internally balanced. By that, I mean L-16 engine do not need an out of balance flywheel, or crank pulley to balance the engine. However, Nissan may have made a minor adjustment in the assembled engine balance by putting some drilled holes in the crankshaft pulley, or the holes could have been drilled to balance the individual crankshaft pulley before it was put on an engine. I believe the pullet is cast steel, and casting variances do occur and after the v-belt grooves are machined, the pulley is then "spin" balanced. Most USA L-16 engines, from 1970 on had an air pump to reduce exhaust emissions. That is what the double groove pulley is used for. Datsun used a few different methods to put ignition timing marks on an engine. Some pulleys have several notches, and use a single pointer on the cam chain cover. Other pulleys use one notch, and a saw tooth pointer on the cam chain cover. The ignition pointer can be on the right or left side of the engine. Use the pulley that works with the ignition timing pointer style, and position that matches the cam chain cover you use. 1 Quote Link to comment
Datsunthug Posted March 22, 2016 Author Report Share Posted March 22, 2016 Thanks Daniel. I got the block back today from getting tanked. all the pulleys, brackets etc were painted also. Checked the clearance on the top rings of each cylinder. .046 cylinder 1 .050 cylinder 2 .045 cylinder 3 .046 cylinder 4 The manual specs out between .25-.40 (0.0098-0.0157 top ring end gap. Don't know how much compression will be lost with it being a little beyond tolerances Trying to find someone or a place to rent a dingleberry hone EDIT: top ring specs. Sorry .25-.40 (.0098-.0157) 1 Quote Link to comment
4perrev Posted March 23, 2016 Report Share Posted March 23, 2016 I cleaned my pistons, slapped new rings on there, deglazed the cylinders and fired her up. Runs like a champ for over two months now. All stock rings replaced. shouldn't have to worry about it too much. Just my opinion though! 2 Quote Link to comment
Datsunthug Posted March 28, 2016 Author Report Share Posted March 28, 2016 Having a shitty time finding a ball hone for my cylinders?!?! They cost more than a bill from a machine shop and no one around my area (that I know) has one. All the tool rental places around only have the bar type. 1 Quote Link to comment
hobospyder Posted March 28, 2016 Report Share Posted March 28, 2016 http://www.amazon.com/s/ref=sr_pg_1?rh=i%3Aaps%2Ck%3Aball+hone&keywords=ball+hone&ie=UTF8&qid=1459125701 :confused: :confused: :confused: 1 Quote Link to comment
Datsunthug Posted March 28, 2016 Author Report Share Posted March 28, 2016 What is the appropriate grit to hone them holes out? 1 Quote Link to comment
4perrev Posted March 28, 2016 Report Share Posted March 28, 2016 Just use a standard bar type and the rings will seat fine. I say all this, cause it's what I did and she runs great!! 1 Quote Link to comment
Datsunthug Posted April 19, 2016 Author Report Share Posted April 19, 2016 can't wait to put the engine together this weekend! I appreciate all the tips guys. I'll post some pics if I can figure out why photo bucket is being a bitch. That's a crappy app for sure. 2 Quote Link to comment
4perrev Posted April 19, 2016 Report Share Posted April 19, 2016 Gotta do the bucket thing from your computer, not you're phone. Works muy bueno!! 2 Quote Link to comment
flatcat19 Posted April 19, 2016 Report Share Posted April 19, 2016 Works just fine from my phone. 1 Quote Link to comment
Datsunthug Posted April 25, 2016 Author Report Share Posted April 25, 2016 Engine is together!!!!!! Just need to check the valve lash and then take it off the stand to install the rear seal and new clutch!! Had some trouble with the front cover. A bolt had broken off to mount the water pump and I didn't see it until I had mounted it. Fail on my part. Luckily I had another from the extra motor. And extra gaskets and a front seal. Thanks for the tips guys. Pics soon 1 Quote Link to comment
4perrev Posted May 2, 2016 Report Share Posted May 2, 2016 Sweet! Get her running and you'll be grinnin' all day long!! 2 Quote Link to comment
Datsunthug Posted May 12, 2016 Author Report Share Posted May 12, 2016 Engine was put in yesterday! Going through the wiring to find out why the starter isn't getting juice. When I first got the truck there was an issue with the wiring it wouldn't start, and then I jostled around some wires and magically it started. There must be a short somewhere and I hate electrical so this will be fun 1 Quote Link to comment
DanielC Posted May 12, 2016 Report Share Posted May 12, 2016 521 electrical diagram. Battery negative grounds to head, by fuel pump. Big battery positive, to big terminal on starter solenoid. A thick wire also goes to the fusebox from battery positive. This wire is connected on the engine side of the fuse box to a thick white wire, that goes into the wiring harness. This white wire goes into the cab, and to the ignition switch. The ignition switch connects power to a black wire, with a yellow stripe, when in crank position. the ignition switch makes other connections too, but black wire, yellow stripe is the "crank" wire. The black wire, with a yellow stripe goes to the 1/4 inch spade connector on the starter solenoid. 1 Quote Link to comment
Datsunthug Posted May 12, 2016 Author Report Share Posted May 12, 2016 Thanks Daniel! Everything is wired correct. I'm hoping maybe a loose connection to the ignition switch, or a bad/ broken wire. Going to bust out a test light when I get off. It's SO CLOSE!?!? I feel like it's Christmas 1 Quote Link to comment
Datsunthug Posted May 12, 2016 Author Report Share Posted May 12, 2016 Shit is about to get real folks!! 1 Quote Link to comment
banzai510(hainz) Posted May 12, 2016 Report Share Posted May 12, 2016 we are waiting 2 Quote Link to comment
Datsunthug Posted May 12, 2016 Author Report Share Posted May 12, 2016 Need to find a brake locking plate assembly? Missing the driver front?? Does any place sell these? 1 Quote Link to comment
flatcat19 Posted May 12, 2016 Report Share Posted May 12, 2016 Locking plate? 1 Quote Link to comment
Charlie69 Posted May 12, 2016 Report Share Posted May 12, 2016 A picture of the part would be helpful. In this brake down from your description I am guessing you are talking about Item #65 Link to Manual image is from: Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 Yeah the u shaped pieces that lock in the adjuster from the back side of the drum Oh by the way........ Got her running!!! Might have to pull the distributor and oil pump to get the timing right. Had to adjust it totally retarded ( dizzy adjusted all the way left) to get it to run. The muffler seam was rusty and broke so now I have no exhaust which makes it sound like a mini stock at the racetrack. But the no muffler is more quiet than my birthday party last night. Haha 1 Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 Charlie it's numbers 61,62,63. 1 Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 Celebrating with a few shots of jaeger and Jamison because victory is sweet 1 Quote Link to comment
Datsunthug Posted May 13, 2016 Author Report Share Posted May 13, 2016 $207 Rock auto (all the internal engine shit) $120 battery $7 car wash Free oil and filter About $30 worth of silicone, anti seize, lithium grease etc. and probably 250 beers Yep that's what it costs to rebuild a Datsun. And all the pointers from you fellow ratsun members 1 Quote Link to comment
